1Back to top Go down   k100 test temp sensor / coils  Empty k100 test temp sensor / coils Sun Nov 17, 2019 7:44 pm
yankeeone
Hi, I am having trouble with my 86 k100. Hard start, rough running , white smoke, ect.
I have tried all the stuff. Today I just tested the tem. sensor, # 10 pin and ground and got 2.14 ohms. Tested the coils on the spark plug sockets and got 9.76 k ohm.
How do those numbers sound ?
For some reason its 1 and 4 cylinders that seem to be hard to fire.
2Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Sun Nov 17, 2019 11:24 pm
White smoke can be the coolant leaking into the combustion chamber and those numbers are OK if the engine is at ambient temperature.
3Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Mon Nov 18, 2019 2:58 am
yankeeone wrote:Hi, I am having trouble with my 86 k100. Hard start, rough running , white smoke, ect.
2.14 ohms ?....I hope you mean 2.14 k ohms ...and I hope the engine was cold when you took the measurement
at 2.14 ohms the fan should have been running for quite some time .... as it triggers the temp - fan relay  at about 100 ohms
usually we measure the resistance to the temp sensor at the under seat ecu on pins 10 and 13 ....can make a difference , as this is what this ecu sees ...rather than a faulty path to ground , which is quite common ,,,and one of the faults with the temp sensor (corrosion between the temp sensor and the water stub housing ---in the threads , caused by dissimilar metals and the stuff in the radiator system creating a bad earth path )
don't forget that on all the early 2 valve k bikes  the temp sensor that controls the ecu is a double sensor within  the same device , the third contact is the water stub earth path .
4Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Mon Nov 18, 2019 9:44 am
yankeeone
Thanks guys, what should I expect to get for readings on the ecu connector on pins 10 and 13?
It seems most of the problem is on 1 and 4  , the exhaust pipe are cold , and when I can finally get some rps going they are cooler than 2 and 3.
5Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Mon Nov 18, 2019 10:43 am
First of all, if it was the temperature sender, ALL the cylinders would be giving you trouble.
Second, early K100 coils have a reputation for failing.  I suspect you have a bad one.  It may not be a bad idea to replace the coils with the later version.
A test might be to swap your coils and see if the problem moves to the other cylinders.
6Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Mon Nov 18, 2019 1:06 pm
yankeeone wrote:I am having trouble with my 86 k100. Hard start, rough running , white smoke, ect.
Which stuff is that—Ambien, Excedrin, Cialis, Ecstasy? .75's coil swap seems sensible; a compression test might be useful, too.
7Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Mon Nov 18, 2019 3:30 pm
yankeeone
Stuff/
Switched computer under the seat with known working one
switched control unit under the tank with known working one
hall unit
valve check
compression test
switched coils with known working coils
tested fuel pump pressure
plug wires are new
do have spark on 1 and 4
switched air flow meter with known working one
removed injector rack and checked for fuel from injectors
checked for vacuum leaks
checked breather hose
8Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Mon Nov 18, 2019 3:48 pm
yankeeone
Point seven five, I agree with your assessment. I did swap coils ,but no help.
The bike was running great. Just rolling along at seventy five, then sudden loss of power.
When trying to start now, early cranking ,trying to start leaves 1 and 4 exhaust pipes cold, If can get some rpms up then they get hotter. but not as hot as 2 and 3
9Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Mon Nov 18, 2019 4:28 pm
Check the wiring to the coils.
10Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Mon Nov 18, 2019 9:37 pm
Another easy check on the coil and leads is to remove  the coil cover and the spark plug cover plate and run the bike at night in the dark  and hopefully you don't see any blue  dancing lights
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
11Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Tue Nov 19, 2019 4:37 am
or in this case hopefully you WILL see dancing sparks ,  enough to be able to identify issues
I might add , a set of  coils off a working bike  , doesn't mean that they are good in all respects , had a set recently that idles ok , with a struggle ...but broke down on acceleration and higher revs - only .....
removing the coil cover let me hear the jumping over of the high energy spark and identify the bad one , im as blind as a bat anyhow ...smile
12Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Tue Nov 19, 2019 6:01 pm
yankeeone
Thanks, I will try running the bike in the dark, it just got dark here.
I think I will try a test for continuity on the harness side of hall sensor and coils.
13Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Tue Nov 19, 2019 8:28 pm
yankeeone
Solved --  spark plugs, particularly number one , they only have about 5 thousand miles on them , so looks like a failing coil as well.
Thanks for your help
14Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Tue Nov 19, 2019 8:49 pm
Anyone mentioning problems, 1 and 4 are on one coil, 2 and 3 on the other. Anything affecting 1/4 together or 2/3 together its most likely to be coil or coil wiring related. Swap coils and see if it changes with them. If it does then its coil. If not then its coil wiring which can include one of the two Hall sensors.
15Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Tue Nov 19, 2019 9:07 pm
yankeeone wrote:Solved --  spark plugs, particularly number one , they only have about 5 thousand miles on them , so looks like a failing coil as well.
What did you see???  What is wrong with the spark plugs?  What was the coil doing??  I thought you swapped coils and the problem stayed on cylinders 1&4.
16Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Tue Nov 19, 2019 9:19 pm
yankeeone
Like a lot of things that go wrong, it seems to be a series of little things that add up.
I am thinking that due to a weak coil the plugs took on a lot of carbon, I did change coils but with one that was
probably not much better, so it couldn't overcome the carbon plugs.
I did test the spark on number one cylinder early on and when it was out it did spark , and they didn't seem
bad visually, but apparently they were.
 I will get new coils.
17Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Tue Nov 19, 2019 10:23 pm
What spark plugs have you? Do they have bobbins on them or do they show a threaded top?
18Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Tue Nov 19, 2019 10:24 pm
Point-Seven-five wrote:First of all, if it was the temperature sender, ALL the cylinders would be giving you trouble.
This was the one to follow as an early test.
19Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Sat Nov 23, 2019 5:22 pm
yankeeone
Hi, Installed updated version of the coil. Runs great. I think a weak coil allowed the plugs to foul. when I put in new plugs she ran, and now with new coil she runs better then ever.
It seems I will need new bigger screws for the cover and a little shimming of the coil spacing to get the old coil cover to work.
I bought the coil from Bobs BMW ,good price and got it in two days.Now I need to get another one for # 2 and 3
 Now I can continue on with the RT to RS conversion and repaint.
20Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Sat Nov 23, 2019 7:14 pm
that's a good result so far
good luck with the rest of it
21Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Sat Nov 23, 2019 8:20 pm
Thanks for the update.  Those early coils have caused a fair number of headaches.
22Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Sat Nov 23, 2019 8:41 pm
yankeeone
It has some clean connections now too!
23Back to top Go down   k100 test temp sensor / coils  Empty Re: k100 test temp sensor / coils Sun Nov 24, 2019 10:06 am
You discovered something I discovered.....to get the coil cover to fit you need either two old coils or two new type coils.....I found it doesn't fit if you mix the two types...I have both coil and cover types here. I needed to replace the coils in my new 83 RS and put one new one in...cover would not fit so I swapped the second one as well since I had them.
