1 Fuel pump for aux tank Sun Nov 24, 2019 9:30 pm
Packo
I have fitted an aux tank and used a low pressure pump (5-6 psi). To get the fuel into the bike main tank I have teed into the fuel return line and used a one way valve at the joint to stop any feed back into the aux tank.
The aux tank is fitted in a sidecar.
All worked as expected in the garage with the engine off.
However, when travelling the system is very unreliable. The pump is on a timer switch and sometimes I get a full quantity of expected fuel (rarely) and others I get varying amount from half the expected amount to nil (more often it is the latter). Always the expected amount is delivered when pumped with engine off.
I am suspecting that the pump needs to deliver higher pressure for the fuel to get into the return line if the system is to work properly.
If I am right does anyone know the what psi is in the return line, all I know is that it is low pressure, hence the low pressure fuel pump. I have used this system before but must have fluked the correct fuel pump because it has been successful. But at $230 per pump it is a bit pricey.
If I am on the right track with my thinking about the pump psi being too low I could try to match the pump to the pressure in the return line OR what would happen if I used a standard high pressure pump, would it put undue pressure at the FPR or would it merely take the line of least resistance and deliver the fuel as required into the tank???
Open to suggestions.
______________
83 K100 HRD Outfit
1992 K1100 Outfit
2003 R1150 GSA Outfit
1983 K100 Basic
