1Back to top Go down   Mix & Match? Empty Mix & Match? Thu Nov 07, 2019 1:28 pm
tjh1985
tjh1985
Hey Guys,
Have a buddy who saw my k100 and ran out and bought one for himself. He’s new to K-Life so hes not on the forum just yet, but is in a pickle. Woukd love sone help...
He bought a 90’ k100. It needed some parts and he ordered a 87’ k100 left front caliper. He also ordered a 90 k75 brake pipe (hard line that connects 2 front calipers) will these 2 parts work on his ‘90 k100?
Appreciate the guidence
http://www.thomashurst.com
2Back to top Go down   Mix & Match? Empty Re: Mix & Match? Thu Nov 07, 2019 1:49 pm
Which model and year is your K100; which model is his K100?
3Back to top Go down   Mix & Match? Empty Re: Mix & Match? Thu Nov 07, 2019 2:57 pm
tjh1985
tjh1985
His bike is a 1990 K100lt. The parts he ordered - Left Front Caliper off a 1987 K100 (model unknown) and he got a Brake Pipe [the hard line that connects the two front calipers] off a 1990 K75 (model unknown). The question is will those parts work on his bike?
My bike is a 1985 K100rs, but is not involved with the question above.
Hope that’s help and appreciate any insights.
4Back to top Go down   Mix & Match? Empty Re: Mix & Match? Thu Nov 07, 2019 4:18 pm
the forks are basically the same  and the callipers should also be the same  if its an lt  , at best guess
if it was an rs of that year could well be different with 4 pot callipers ? and 16 valve head ?
hope that helps , but best if we could see what he bought and what its to fit
good luck
5Back to top Go down   Mix & Match? Empty Re: Mix & Match? Thu Nov 07, 2019 6:41 pm
volador
volador
6Back to top Go down   Mix & Match? Empty Re: Mix & Match? Thu Nov 07, 2019 10:29 pm
tjh1985
tjh1985
Appreciate the leads on matching parts - I’ll look at the PM now
7Back to top Go down   Mix & Match? Empty Re: Mix & Match? Thu Nov 07, 2019 10:36 pm
volador wrote:Check parts compatibility with "BMW MAX Microfiche", BOBS BMW, REAL OEM
https://shop.maxbmw.com/fiche/PartsFiche.aspx
https://shop.maxbmw.com/fiche/PartsSearch.aspx
https://www.bobsbmw.com/store/microfiche/BrowseSeries.aspx
https://www.realoem.com/bmw/select.do?kind=M&arch=1
Cross reference parts like Bosch pn#'s, etc....  http://partsplusecat.com/
you have PM for your tranny
That's just factory compatibility.  There's a lot more compatibility than is shown there.  For example the brake line the OP is looking at (part 34322312691) will show as being only for K75s but it will also work on K100s with a two piece front fender.  I know that because my K100 has one.
8Back to top Go down   Mix & Match? Empty Re: Mix & Match? Fri Nov 08, 2019 3:01 am
The calipers will fit, no problem, they're the same.
The brakepipe won't fit, frontfender is different.
Mix & Match? Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
9Back to top Go down   Mix & Match? Empty Re: Mix & Match? Fri Nov 08, 2019 7:24 am
Arlina wrote:The calipers will fit, no problem, they're the same.
Tell that to my K100 that has one.  It'll fit under the two piece K100 but probably not under the early one piece front fender.
10Back to top Go down   Mix & Match? Empty Re: Mix & Match? Fri Nov 08, 2019 3:31 pm
The "normal" K100 8V has the old fender Very Happy
