1Back to top Go down   wiring speedo Empty wiring speedo Wed Nov 06, 2019 2:42 am
jensen
jensen
Hi everybody,
i'm wiring my speedo and I can not seem to get everything right as it should
be.
documents are in following pictures.
wiring speedo D2867112
wiring speedo Instru11
so i can't get the light of the neutral stand work when its in neutral.
can anybody tel my what wires i should connect.
then,
light of the blinkers work but don't blink.
probably because its led but i'm not sure how to fix it.
last,
there's a speed sensor with the speedo going to the front weel.
any chance there's a possibility to use the original speed sensor
kind regards,
jensen
2Back to top Go down   wiring speedo Empty Re: wiring speedo Wed Nov 06, 2019 9:27 am
Tell us which connections you have made and the wires making them.
3Back to top Go down   wiring speedo Empty Re: wiring speedo Wed Nov 06, 2019 9:47 am
jensen
jensen
My bike is a k1100 1992 btw.
Made a connection between neutral of the speedo and number 5 of the schedual( starter switch , clutch in or gear=0)
Little details. Can’t crank my bike yet . But I should think that the light should be on without the motor be started?
4Back to top Go down   wiring speedo Empty Re: wiring speedo Wed Nov 06, 2019 10:09 am
Please provide wire colors.
5Back to top Go down   wiring speedo Empty Re: wiring speedo Wed Nov 06, 2019 10:31 am
jensen
jensen
Brown Speedo wire to black/green
