1Back to top Go down   Hi from Toronto, Canada Empty Hi from Toronto, Canada Wed Oct 30, 2019 3:49 pm
gurka
gurka
Picked up a 87 K-100RS in San Diego last summer while I was living in San Francisco. Have moved back to Toronto now for good and bike is sitting at the border in Buffalo at a friend's place about to be exported and imported to Canada next week. Just in time to store it for the winter...
Bike is in good condition, I did a few things when i got it last year:
- new tires
- new clutch cable
- motor oil oring replacement - had a small leak
Has 2 issues would like to work on this year over winter:
- mirror on right side keeps falling off. Looks like the strange looking fastener 3-point locker is expanded and won't hold it in place on the little ball mount. Tried tightening the mount on the mirror but looks like it's lost it's strenght and I'll likely need a new complete mirror unit
- speedometer sometimes will drop to 0 while riding and not function for a minute, then it starts to work fine and won't do it again for a long while
IMG-4226
IMG-4213
IMG-4217
2Back to top Go down   Hi from Toronto, Canada Empty Re: Hi from Toronto, Canada Wed Oct 30, 2019 5:36 pm
welcome aboard
the mirror fastening clips can be replaced with new
often the speedo sensor connection under rhs sidecover can be corroded  in addition to wear of the instruments connector  and other little things inside the instruments ...I guess its galvanic corrosion issue   good luck
 lots of entrys to that fix throughout the forum   use the search feature found on the "portal page "
3Back to top Go down   Hi from Toronto, Canada Empty Re: Hi from Toronto, Canada Wed Oct 30, 2019 5:59 pm
gurka
gurka
charlie99 wrote:welcome aboard
Great thanks for the tip on the mirror fastener clips. Do you know where i could order those?
4Back to top Go down   Hi from Toronto, Canada Empty Re: Hi from Toronto, Canada Wed Oct 30, 2019 6:08 pm
try a bmw dealer , bobs bmw in the states etc or other suppliers ,  they aren't expensive
or
out here we get a lot of stuff from either motorworks   or motobins in the uk  freight extra of course  so best to order with a number of parts to share out the cost
