1Back to top Go down   Longer clutch cable Empty Longer clutch cable Fri Oct 11, 2019 12:14 am
Dealer925
Dealer925
Being of old age and bad back I need to change the rider position. I found some new handle bars and risers and they are perfect. The problem is the clutch cable is now to short the bike is a K100rs. Is the clutch cable for the RT or LT model any longer or where can I get an after market clutch cable. I also need a longer brake master cylinder hose. Any advice will be appreciated......BOB
2Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 12:35 am
You need the RT/LT clutch cable, it is indeed longer. You may most likely need the RT/LT brake hose and possibly throttle cable.
The wiring is same but you will need to pull out the  from under the gas tank.
3Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 12:45 am
Davep
Davep
Motorworks.
Best place to get the cables. I've opted for C bars but did consider LT/RT on for my RS but when I looked in to it Motorworks came out on top!
Best of luck
Dave
Longer clutch cable Eu-log10BMW K100RS 1983 (Main ride)
                      Suzuki GSX 750 ET 1979 (Needs work)
                      Kawasaki Zephyr 750 1992 (Needs hiding)
4Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 12:59 am
Dealer925
Dealer925
Thanks guys that gives me a couple options......BOB
5Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 1:11 am
The C clutch cable is the same as the RS one.  The RT/LT clutch cable is 115mm longer than the RS cable.
6Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 7:23 am
Davep
Davep
As Duck says, the LT/RT cables are longer, that's why I'm going over to C bars. I replaced the cables on my RS (Clutch cable snapped so thought I would do them all) then a couple of months later decided I wanted the more upright riding position. Not going to do all that cable work again!
Dave
7Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 10:41 am
I thought however there were only two throttle cable lengths but was told there are more. I have a K100RS and it came with a spare RS throttle cable which I thought would work with the C bars I got for it.....only to find that the clutch cable works but throttle cable does not!!! Seems the front brake line from master cylinder to headstock also must be changed for C bars.
8Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 1:29 pm
92KK 84WW Olaf wrote:Seems the front brake line from master cylinder to headstock also must be changed for C bars.
Not necessarily.  On some bikes you can loosen the banjo bolt on the bottom of the front master cylinder and changing the angle that the line comes out will make it so that the original brake line will work.
9Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 1:46 pm
Longer clutch cable A9NXDXC
10Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 2:00 pm
yamaguzzi
yamaguzzi
What exactly are "c" bars ?  What are they off ? What about other aftermarket bars? I am thinking of putting different bars on my 1988 K100 RS  because of the pain I get in my wrist and shoulders when I ride it.Don't get that with my Moto Guzzi 850 T or any of my other bikes just this K . The stock bars put my hands at an uncomfortable angle and after about 20 minutes the pain starts.
11Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 2:13 pm
The C-bar came with the K75C model. Its height is between that of the S and RT models' handlebars. MaxBMW's fiche has photos of the difference in the Handlebar section of the Steering diagrams of different models.
12Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 2:36 pm
yamaguzzi
yamaguzzi
Thank you
13Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 2:50 pm
Dealer925
Dealer925
Thanks guys you have opened up a lot of options for me.....BOB
Glad to see there are other old guys riding these things...LOL
14Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 3:24 pm
When searching for aftermarket bars, be aware that BMW bars are 22mm in diameter but many aftermarket bars listed as 22mm-7/8 are actually 22.2mm. Stock controls won't easily fit onto them without first sanding down the handlebar to allow fitment. Those who have forced the issue often have broken the switch housings.
Flanders makes several models dedicated to the BMW measurement.
15Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 3:31 pm
What he said.  I've never found anybody but Flanders that makes true 22mm handlebars.
16Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 3:43 pm
volador
volador
"C" bars  32 71 2 303 050   NLA
Longer clutch cable 32712303050_1_B
Longer clutch cable 32712303050_3_B
Longer clutch cable 32712303050_2_B
17Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 4:21 pm
volador
volador
A close match to the C-bars from Krator
Longer clutch cable Jbm-105-b-1
Ebay krator bars
18Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 6:57 pm
I think the heated grip C bars are still available - 32712300085
19Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 7:29 pm
volador
volador
duck wrote:I think the heated grip C bars are still available - 32712300085
what is the difference heat vs non-heated bars?
20Back to top Go down   Longer clutch cable Empty Re: Longer clutch cable Fri Oct 11, 2019 7:44 pm
Heated grip handlebars have a hole drilled in the front middle for heated grip wiring to pass through.
Also two threaded holes on the left side for the heated grip to screw onto.
And notches in the ends for the HG wiring.
