1Back to top Go down   Intro/ECU CDI Empty Intro/ECU CDI Tue Sep 03, 2019 1:55 am
Darcy
Darcy
Hi everyone, I'm Darcy from Australia and have just bought a k100RT 1984, It didn't come with an ECU so haven't started it yet and from what I know hasn't been started for at least 3 years.
Done a little bit of research and have found 2 part numbers - 0227401001 & 0280000313. I know the plug I have is for the 313 ECU but could I change it and use the 001? Any knowledge would be greatly appreciated.
2Back to top Go down   Intro/ECU CDI Empty Re: Intro/ECU CDI Tue Sep 03, 2019 2:02 am
Hello where in Oz are you  ?
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
3Back to top Go down   Intro/ECU CDI Empty Re: Intro/ECU CDI Tue Sep 03, 2019 2:04 am
Darcy
Darcy
Just south of Melbourne
4Back to top Go down   Intro/ECU CDI Empty Re: Intro/ECU CDI Tue Sep 03, 2019 2:15 am
Hi Darcy welKome to the forum. Whereabouts in Oz are you.
AFAIK there is only one ecu for the K100 8 valve engine. Various part numbers are given but one supersedes the other.
https://www.realoem.com/bmw/enUS/showparts?id=0504-EUR-07-1984-K589-BMW-K_100_RT_84_0504,0505,0514_&diagId=13_0515
5Back to top Go down   Intro/ECU CDI Empty Re: Intro/ECU CDI Tue Sep 03, 2019 4:03 am
Welcome Darcy Smile
Got yourself a project.
I have some of those, but located on the other side of the world.
Intro/ECU CDI Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
6Back to top Go down   Intro/ECU CDI Empty Re: Intro/ECU CDI Tue Sep 03, 2019 4:31 am
volador
volador
Welcome! Good Luck with your moto! You need both units.
Those part numbers are the Bosch CDI 0227401001
Intro/ECU CDI Bosch011
The Bosch ECU 0280000313
Intro/ECU CDI Bosch012
Intro/ECU CDI Bosch013
7Back to top Go down   Intro/ECU CDI Empty Re: Intro/ECU CDI Tue Sep 03, 2019 4:36 am
Darcy
Darcy
Thanks everyone! I think I'll be using this forum a lot!!
Yeah those part numbers have different amount of pins therefore not fitting. Can find the one I'm after for $220aud which not sure if that's a good price or not
8Back to top Go down   Intro/ECU CDI Empty Re: Intro/ECU CDI Tue Sep 03, 2019 8:51 am
Darcy wrote: Can find the one I'm after for $220aud which not sure if that's a good price or not
There are two control units in your moto. Photos of them are supplied by volador. There is one under the seat for fuel injection control. In the numbers you have supplied, its number ends with 0313. There is one within the frame toward the front of the moto for ignition control. In the numbers you have supplied, its number ends with 1001).
Which one are you after?
9Back to top Go down   Intro/ECU CDI Empty Re: Intro/ECU CDI Tue Sep 03, 2019 9:09 am
Which one is it that you want. I can do a hell f a lot better on price than that.
10Back to top Go down   Intro/ECU CDI Empty Re: Intro/ECU CDI Tue Sep 03, 2019 9:12 am
Darcy
Darcy
Oh right I'm with ya now, I need the fuel injection control, the silver box that sits under the seat.
