1 Clutch and Clutch Cable Change Sat Oct 05, 2019 3:51 am
Arrowkeen
Hi Everyone, Have installed new clutch disc and clutch cable
Adjusted as per Chris's instructions- 75mm at end of clutch cable and 5mm play at lever
When bike is on Center Stand and idling in neutral-adjusted idle to around 900rpm, the back wheel is spinning around slowly, when you hold the back wheel, you can feel friction or say clutch pulling the wheel and when you pull in clutch lever in neutral, rpm rises around 300-400 rpm from idle
Is this just the clutch bedding in?
I would of thought that pulling the clutch lever in, in neutral should have no effect on rpm
Any suggestions on this or is this normal with new clutch?
