kioolt
Number of posts : 171
This could be a sign that your starter brushes are worn or that your stater commutator is very dirty. The starter acts as a ground path for the load shed relay's control circuit. If you have certain starter problems the load shed relay will chatter while the bike is running. The load shed relay controls power to the headlight. While it is chattering the headlight will either cut completely off or dim. Have you had any starter problems where the starter would not spin? That is one sign.
Try checking the voltage at the battery when the problem is happening. If the voltage is basically steady then I wouldn't suspect the voltage regulator.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
