1 Final drive Sun Jul 21, 2019 4:44 pm
smoll1
Hi all,
Just a quick question I hope someone knows the answer to.
I have to change the smaller seal on the final drive. It was leaking slightly for a while. I noticed this about 12months ago when I changed the large seal behind the wheel.
The small one now at the point it needs changing.
The rest rest of the drive is fine and I have read all manuals and have the tools just not sure about whether,
1) do I need to change the nut, threaded ring and compression ring. Not really sure .I'm only changing seal do these need to be renewed as well?
2) it mentions using hylomar sq37. Can't seem to find this type anyone have any idears of what to use.
I won't be stripping whole final drive down as it does not need it. Am I right in thinking that if I only remove the nut and castle nut and put in new seal I won't have to muck around with backlash etc.
Any advice would be appreciated.
