1Back to top Go down   Delete me please Empty Delete me please Mon Sep 18, 2017 2:10 am
Overture
Overture
Sadly gang I've decided to remove the thread. Thanks for the DMs and messages.
1984 K100RT (Now Naked)
2Back to top Go down   Delete me please Empty Re: Delete me please Mon Sep 18, 2017 3:04 am
well we/ve seen worse
good luck
3Back to top Go down   Delete me please Empty Re: Delete me please Mon Sep 18, 2017 6:49 am
charlie99 wrote:well we/ve seen worse
I've done worse and it only took one off, not four!! Delete me please 44271
4Back to top Go down   Delete me please Empty Re: Delete me please Tue Sep 19, 2017 5:41 am
Overture
Overture
Deleted.
5Back to top Go down   Delete me please Empty Re: Delete me please Tue Sep 19, 2017 5:53 am
yellow light is the  ...ahem ...choke lever activated ....there is a switch on the throttle cam activation to the throttle bodies ..(same type switch as brakes and clutch lever )
good work !!!!!
sounds like a k bike to me already
6Back to top Go down   Delete me please Empty Re: Delete me please Tue Sep 19, 2017 6:14 am
Overture
Overture
Deleted.
7Back to top Go down   Delete me please Empty Re: Delete me please Tue Sep 19, 2017 6:23 am
maybe the switch is toast or just needs cleaning ?
wont be the first that we have seen go west
but possibly there is a slight adjustment issue  with the cable - or throttle bar set screw
I guess in time that will be sorted ...after a bit of a tune up
the service manuals are available right here in the forum
just look for the downloads section ....prerequisites are number of posts ...and the magic password
good luck
8Back to top Go down   Delete me please Empty Re: Delete me please Tue Sep 19, 2017 6:42 am
Overture
Overture
Deleted.
9Back to top Go down   Delete me please Empty Re: Delete me please Tue Sep 19, 2017 10:38 am
10Back to top Go down   Delete me please Empty Re: Delete me please Tue Sep 19, 2017 10:43 am
Overture
Overture
Deleted.
11Back to top Go down   Delete me please Empty Re: Delete me please Tue Sep 19, 2017 11:58 am
Good progress. I can't believe the state of the fuel pump rubber. I've seen pictures of them before but it never ceases to amaze me.
Delete me please Ir-log1188....May contain nuts!Delete me please Ir-log11
K75RTP - 1994
12Back to top Go down   Delete me please Empty Re: Delete me please Tue Sep 19, 2017 12:47 pm
Try soaking the old pump in vinegar for a week or two. Sometimes soaking and applying 12v briefly then alternating the + & -  can break them free. If it has signs of life and it looks like it is trying to move either resoak or you can up the voltage very briefly to 18v and try alternating the connections. Always good to have a spare.
13Back to top Go down   Delete me please Empty Re: Delete me please Sat Sep 23, 2017 5:09 am
Overture
Overture
Deleted.
14Back to top Go down   Delete me please Empty Re: Delete me please Sun Feb 25, 2018 8:59 pm
Overture
Overture
Deleted.
15Back to top Go down   Delete me please Empty Massive bumb Tue Feb 21, 2023 11:17 am
Overture
Overture
Deleted.
16Back to top Go down   Delete me please Empty Re: Delete me please Tue Feb 21, 2023 11:25 am
Overture
Overture
Deleted.
17Back to top Go down   Delete me please Empty Re: Delete me please Tue Feb 21, 2023 11:47 am
Overture
Overture
Deleted.
18Back to top Go down   Delete me please Empty Re: Delete me please Tue Feb 21, 2023 12:04 pm
Overture
Overture
Deleted.
19Back to top Go down   Delete me please Empty Re: Delete me please Tue Feb 21, 2023 3:03 pm
Why not just make a complete new wiring loom? You don't have to use the original BMW-type block connectors (Molex will do) and if you've got this far with modifying the loom, then you'll know exactly what you have to replicate it to fit the bike. The specialist terminals for the FICU and ICU are widely available.
Good on you to coming back to this. Far too many end up in the skip.
20Back to top Go down   Delete me please Empty Re: Delete me please Wed Feb 22, 2023 12:28 am
Overture
Overture
Deleted.
21Back to top Go down   Delete me please Empty Re: Delete me please Wed Feb 22, 2023 6:28 am
Overture wrote:expanding wrap
Hmmm. I'm not a fan of that stuff - I use PVC sheathing and plan my wiring looms so that where the wiring branches off, it goes into a smaller diameter tube etc. etc.. No tape anywhere and if properly planned, no exposed wires until they meet the connector. One of the reasons I don't like tape is that if you do make a booboo it's very difficult to un-booboo it. Secondly, taping wires tightly together can lead to heat buildup which is not something you really want.
22Back to top Go down   Delete me please Empty Re: Delete me please Wed Feb 22, 2023 11:51 am
Overture
Overture
Deleted.
23Back to top Go down   Delete me please Empty Re: Delete me please Thu Feb 23, 2023 9:50 am
Overture
Overture
Deleted.
24Back to top Go down   Delete me please Empty Re: Delete me please Fri Feb 24, 2023 7:10 am
gasket for the hall sensor!
Next time you need one (and you will - it's cork and it will disintegrate when you take the cover off) make one from 1.5mm or 2mm rubber sheet instead. Put the cover on the sheet and lean on it to indent the shape, then cut it out. A 6mm hole punch is helpful to -ahem!- punch out the screw holes. You don't have to make a perfect internal shape where the screw holes are either as it's only wires running underneath.
