I agree with Ajays and TWB. The only way to try solving the problem without a major tear down is by flushing the engine.
A sprag clutch is made of small springs and sprags. It works on the same principle as a free wheel. One of the most common application of the freewheel is the hub on a back bicycle wheel:
Here is the principle of a free wheel.
The small springs keep the rollers lightly in contact with the outer ring .
When the outer ring is rotating CCW, it will squeeze the rollers against the ramps locking the inner and outer rings together.
When turning CW, the squeeze is released and the small springs will give just enough pressure on the rollers to have them sliding against the outer ring.
The 2 majors problems on a sprag clutch are:
- the system is gummed up and nor the rollers or the springs work freely (common on K bikes).
- The ramps are marked and it prevents the rollers to ride freely on them.
The explanation of the free wheel principal should help you to understand how the sprag clutch is working.
What is a sprag?
a. A piece of wood or metal wedged beneath a wheel or between spokes to keep a vehicle from rolling.
b. A pointed stake lowered at an angle into the ground from a vehicle to prevent movement.
The sprag clutch is working on the principle of friction too. On the picture of this clutch, when the inner race is turning CCW, it will drag and tilt the sprags and subsequently lock the inner and outer races together.
The starter is driving the inner race and the outer race is the link to the crankshaft.
When the crankshaft is turning at a higher rpm than the starter, the pressure on the sprags is released. The small springs are applying just enough pressure to the sprags to have them sliding on the inner race.
If the system is dirty and the sprags or springs are not working freely, the sprags will not keep a contact on the inner race and this is when the starter will spin but not drive the crankshaft.
On the K engine, the sprag clutch is lubricated by the engine oil. The carbon deposit is what gum the clutch. You have to remove the transmission, clutch and bell housing to access the sprag clutch and clean it. This is why the flushing is the easiest way to go.
The majority of bikes are using sprag clutches for the starter, but on a lot of Japanese one it runs dry and doesn't have any contact with the motor oil. This is why they don't have the same problem.
Hope that help to understand the problem.
Bert
