1Back to top Go down   1985 K100RS radiator needed. Empty 1985 K100RS radiator needed. Fri Apr 30, 2021 10:37 pm
RS Rider
RS Rider
Desperately needed in Canada, a 3-core for my bike. Just been through two previously purchased, both of which leaked. HELP!
2Back to top Go down   1985 K100RS radiator needed. Empty Re: 1985 K100RS radiator needed. Fri Apr 30, 2021 11:37 pm
Use a 2 row core they work just fine. BMW changed to the 2 row core without any problems around 1984 and used them right through to the end of the K1100s
3Back to top Go down   1985 K100RS radiator needed. Empty Re: 1985 K100RS radiator needed. Sat May 01, 2021 12:22 am
RS Rider
RS Rider
RicK G wrote:Use a 2 row core they work just fine. BMW changed to the 2 row core without any problems around 1984 and used them right through to the end of the K1100s
Okay. I’ll take what I can get my hands on then. Any idea why BMW went from a 3-row core to a 2-row core? With a 2-row there would be less coolant in the airstream at any given time provided that the tubes that the coolant flows through are the same size as the 3-row, correct? And I would think that while driving at slower speeds the engine would run hotter. I’ve digressed, but I wonder if BMW thought the engine was being over-cooled?
Thanks for the reply.
4Back to top Go down   1985 K100RS radiator needed. Empty Re: 1985 K100RS radiator needed. Sat May 01, 2021 3:09 am
I've had both in a K100 and K1100 and didn't seem to make any difference. They probably figured that it didn't need the 3 row core.
5Back to top Go down   1985 K100RS radiator needed. Empty Re: 1985 K100RS radiator needed. Sun May 02, 2021 1:51 am
gorio
There is always this.
https://www.ebay.ca/itm/333723246442
There is some recent discussion on here about it.
https://www.k100-forum.com/t16590-ebay-aluminum-radiator-thoughts
1992 K100rs 16v
1997 R1100rt
2006 R1200rt
Past lives
Kawasaki Concours
1976 BMW R90s
1975 Ducati 860gt
1992 Honda VFR750
1985 Honda VF750
1982 Kawasaki 750GPZ
1975 Norton 850 Commando
6Back to top Go down   1985 K100RS radiator needed. Empty 1985 K100RS radiator Thu Jun 03, 2021 1:00 am
gvm
gvm
Have one removed from my working 75K mile bike. Cleaned, repainted, leak tested, thermostat tested, all OK. Never put back on.
New addresses: July 2022. Still have the radiator.
Greg Miller, gvmiller@protonmail.com, 208 351 9873, Macks Inn, ID
1985 K100RS serial #0041331
2013 Kawasaki KLR650
2008 Yamaha WR250R; 2008 Yamaha TW200
