Number of posts : 7967
20 spline refers to the final drive end. The gear box end did not change. Be aware you can actually buy a new splined end for 20 splie shafts and have it welded on to the drive shaft at a machine shop.
At 1985 you may have a 16 spline shaft, you need to check this out more. If you do, they can be harder to find. I have 2 Ks on 16 spline final drives but also have 2 31/11 ratio spares for them.
You can find a 20 spline final drive and 20 spline shaft and just pop them straight in. Mostly the final drive ratios are 31/11 for RS and 32/11 for RT/LT. Its a small difference and I would go on condition/price rather than focus on the small difference in the ratio. A K75 one for rear disc brake will also fit BUT the ratio on those is usually 32/10 but thats a bit out for you at 10%. The ratio is stamped on the top of the final drive casing.
1971 Yamaha 125 YAS-1
