10 Re: Fuel pump Mon May 27, 2019 8:11 am
Number of posts : 7942
stevenh wrote:I have just brought a K100 trike conversion. With it I inherited a bad missfire that makes it unrideable. The trike has had extensive work Compression check, valve clearances, fuel rail acid dipped, new fuel pump and filter, new plugs, coils leads and caps. Anyway checking for the missfire I noticed the fuel pump was not priming. I checked the fuses and one was blown. I replaced it, the fuel pump primed up and the missfire improved considerably. But not for long, now the fuel pump is not priming but the fuses are ok. I took each one out and tested them with a multi meter. I am now wondering if it is a relay.
My electrical knowledge is limited. Does anyone have any clues to the cause of the problem. Is it a relay, and exactly where can I locate the relay. Is there any way to test it
Steve
The photo you have up shows RT/LT fairing.
These were all 2V engines and the fuel pumps on these do NOT prime. They only get power when you press the start button. Nothing happens when you switch on the ignition. On 16v engines you will hear the pump as soon as you switch on ignition and bring kill switch to on position.
To check the relay swap the horn and fuel pump relays and see what happens. They are the same and will swap. All in the box under the fuel tank. These ones are not screwed in or bolted in, just pull them out.
Another point you haven't mentioned is the big plug into the Fuel Injection Control Unit under the seat, a known dodgy point and worth checking pins are clean and the plug is correctly seated.
1971 Yamaha 125 YAS-1
