1Back to top Go down   BATTERY FOR A 1984 k100? Empty BATTERY FOR A 1984 k100? Sat Oct 30, 2010 1:47 pm
gabriel
Hi everyone
I am in the process of replacing my battery and would like to hear from others who have been in a similar situation.
My K100 currently has a Toplite (Yausa) 50309? battery and I am shocked at the prices I was quoted for a replacement battery.
Do I purchase another Yausa battery or are there alternatives. Some claim a battery from a golf buggy is acceptable.!!!!
I am interested in other people's opinion.
Regards
Gabriel
2Back to top Go down   BATTERY FOR A 1984 k100? Empty Re: BATTERY FOR A 1984 k100? Sat Oct 30, 2010 3:40 pm
Toplite is the Yuasa Taiwan brand, the 53030 is the recommended battery for our K bikes, I am not familiar with the 53039. http://www.yuasabatteries.com/pdfs/2010_yuasa_apps_specs.pdf is the link for Yuasa battery models and on page 18 you will find them listed by bike model, there is a more expensive YIX30L-BS fully sealed maintenance free version offered as an alternative for our bikes.
Battery size has been debated before on these pages but I am one of the if it fits bigger is better, brigade. 30 Ah is the recommended size for our bikes and I am happy with that, note some battery models have higher or lower Ah ratings but that can vary on the same battery dependent upon the discharge time it is rated over. I put a 53039 battery in about 4 months ago and was very pleased with the fit and quality.
Don't forget when you fill them with acid that even though they are dry charged you should give them a charge for 24 hours before putting them into service if you want maximum life.
3Back to top Go down   BATTERY FOR A 1984 k100? Empty Re: BATTERY FOR A 1984 k100? Sun Oct 31, 2010 8:07 am
Ajays
Ajays
Golf Buggy Battery is functional if you haven't loaded the bike with absorbing items. Maintenance free gell and an easy fit. I put one on my K100 naked.
Ajays
BATTERY FOR A 1984 k100? Th_Kengine_gif
AJAYS
4Back to top Go down   BATTERY FOR A 1984 k100? Empty Re : BATTERY FOR A 1984 k100? Sun Oct 31, 2010 8:23 am
Dennis
Dennis
I purchased a Toplite 53030, 30Ah battery exactly 4 years ago for my RT. Cost at the time was $104AU. I haven't had any problems with it, never need to trickle charge it and I have left the bike for 5 weeks without starting over winter. Voltage usually checks out at 12.7 after about a week, then stays there. No water has needed to be added, and my charge light can just be seen glowing dimly under the southern cross, normal for a K bike.
So, 4 years for $104 is 50 cents per week. Not too much of an issue there, I could have paid $160 at the time for the genuine Yuasa but elected not to. I'd but the Toplite again I reckon.
5Back to top Go down   BATTERY FOR A 1984 k100? Empty Re: BATTERY FOR A 1984 k100? Sun Oct 31, 2010 10:35 pm
If your battery tray has the narrow indent in it then another option is the excellent, sealed Yuasa YTX20HL-BS-PW which fits right in with the supplied plastic spacer or 'lifter'. The polarity is correct, 20amps is more than adequate on a solid stock charging system, and the remaining physical dimensions are spot on!
I give it, whether it shows signs of needing it or not, about a once-a-month 1.25 amp overnight charge and she's treated me golden for a year. With this technique I tend to get four or five years of use from either lead-acid or sealed batteries, of name-brand quality, on my BMWs. I did once get seven years from an Odyssey PC680, which at last report, was still going strong for the third owner of the battery. I obtained it as a year-old warranty reject from the shop I worked in at the time - in fact nothing was wrong with it. Those batteries have guts!
