1Back to top Go down   Swapping Complete engine & Gearbox Empty Swapping Complete engine & Gearbox Mon May 27, 2019 10:37 am
mike d
Hi all,
There is a BMW club member in the UK (Scotland) who want's to change the engine & gearbox that is in his 1998 K100RS (2 valve). The donor bike is also a 1998 K100RS (2 valve).
Is there anyone out there who has done this and can pass on any hints and tips to do the job. I will be sending him both a BWM workshop manual and a Clymer manual.
I have some gearbox guide pins for him, and if needed BMW tool 26 1 660 for swing arm fixed bearing.
He is planning to take the opportunity to lube the clutch and rear drive splines.
I know the manuals will be detailed, however it's always better to hear from those who have had the practical experience, and may have shortcuts.
The reason for the change: The original engine has covered 170,000 miles and has just made some nasty noises (from his description it sounds like clutch/input shaft splines).
Thanks in advance for your help.
Mike
Suzi Q
Suzi Q
Tip No.1
Tell him to join the forum and post some pics!
The rest is easy  Smile
Actually, my tip for starters is/are A: support the swingarm when the shock is removed - or you risk trapping and damaging the front bellows between swingarm and gearbox. B: Cable tie the clutch release arm to the gearbox when you remove the clutch cable - otherwise the spring inside the clutch release bellows will overextend and probably tear the bellows.
A: It won't damage the boot at the front of the swing arm but the boot may slip off of the transmission.
When I built my K75 Frankenbrick I started with the motor sitting on blocks of wood. I put some additional support under the valve cover as the engines are a bit lopsided when sitting on the oil sump and like to tip over. I laid the wiring harness and relay box on the top of the motor before installing the frame.
Swapping Complete engine & Gearbox LRsBiWU
mike d
That's a good start chaps, thanks.
I will encourage him to join the forum, as I said I would be asking on here for opinions.
O.K. soh wat about the initial strip down - pitfalls and all.
Mike
