1Back to top Go down   Seized mudguard bolts Empty Seized mudguard bolts Wed Jul 03, 2019 11:47 am
chris gleave
chris gleave
Intending to replace fork seals (89 K100RSSE) but fell at the first hurdle. All four horizontal and the longitudinal nuts and bolts fixing the two piece mudguard well and truly seized/corroded with bolts immovable and nuts spinning on their threads. Drilling out the longitudinal one should be fun. Any tips?
2Back to top Go down   Seized mudguard bolts Empty Re: Seized mudguard bolts Wed Jul 03, 2019 4:50 pm
Snod Blatter
Snod Blatter
I used a dremel tool to cut the longitudinal one in half, the nut in the front half is a square thing and once it manages to turn in its enclosure you're absolutely stuffed. But you can remove the front wheel and attack it from underneath, then use mole grips or something to hold the square nut still in the front piece of mudguard and twist out the remains of the bolt.
As for the horizontal bolts.. No idea. Good luck! Laughing
3Back to top Go down   Seized mudguard bolts Empty Re: Seized mudguard bolts Wed Jul 03, 2019 5:51 pm
chris gleave
chris gleave
Thanks for that. I was contemplating taking the wheel off but didn't realise I could reach the long bolt from underneath. Will attack it over the weekend and let you know how I get on.
