1 Low rpm at idle and some chugging Sat May 18, 2019 10:19 pm
Heresy23
Just got this 85 K100 rt. It is well below 1k rpm at idle with “choke “ not on...I keep the “choke” always turned up to avoid stalling at red lights....so after being to running temp it was ok but still below 1k rpms....I’m sure I probably need to adjust the throttle but am new to bmw so I just started learning about the bike....ran fuel injector cleaner over like 400 miles and it ran better at high rpm’s...smoother but tonight I noticed after a long ride it was really struggling at idle without “choke” open.....even some chugging instead of a smooth idle .....just got it a week ago and am startling maintenance over the course of a few weeks.....should I just increase the throttle so at idle it’s around 1k rpms? I know getting to the root of the issue is better but I’m thinking the throttle needs adjusted to raise the rpms at idle and I haven’t seen a lot of info on doing that...maybe I didn’t search good enough....can someone link me to adjusting my throttle to raise the rpms at idle ..sick of riding with the “choke “ on...though it’s not a choke ...lol...you get my point...thank you
Oh to note I did find how to raise the idle speed in the manual...saying there’s a idle adjuster screw behind #2 throttle body.....I’m gotta learn where everything is on this engine....lol.i need gigantic map of where everything is!! i like reading how to do things but explanations from other owners is much easier...thanx again
Assuming that’s the screw (c)I adjust it with ...sorry, .I know this is easy stuff but again I’m new to bmw and most of my older bikes I worked on a lot didn’t have fuel injection...never messed with it on my newer sport bikes ...
WILL ADJUSTING THE IDLE SPEED RESULT IN A PROBLEM THE TPS? READ SOMETHING IN FORUMS THAT IT WILL.....THANX....AGAIN!!!
Last edited by Heresy23 on Sat May 18, 2019 11:07 pm; edited 4 times in total (Reason for editing : Found some info)
