51 Re: Replacing rear master cylinder with a Chinese one Sun Sep 25, 2022 12:03 pm
The SS line has female threaded ends and comes with three banjo fittings. I'll probably use the 90 degree fitting at the master end:
At the caliper end I'll use one of these adapters so that the line goes straight into the caliper similar to the OEM setup:
