1Back to top Go down   Fuel return line into tank Empty Fuel return line into tank Tue Apr 23, 2019 3:17 pm
brickrider2
brickrider2
Some time ago there were some posts that explained a mod that will direct the fuel returning into the tank into the left (pump) side.  Can someone direct me to that thread? TIA  Question
1996 K1100LT
2Back to top Go down   Fuel return line into tank Empty Re: Fuel return line into tank Tue Apr 23, 2019 3:52 pm
This isn't a link to a discussion thread; it's the source of the directive for rerouting the hose.
Click on the site's Portal tab, click on the Tech Pages link, go to the Miscellaneous category, click on the Service Bulletins link, then click on the K75 tab and finally, click on the link indicated by the red arrow. This same directive is included in other models' sections also.
Fuel return line into tank Fuel_t10
3Back to top Go down   Fuel return line into tank Empty Re: Fuel return line into tank Tue Apr 23, 2019 6:12 pm
brickrider2
brickrider2
Thank you.
1996 K1100LT
4Back to top Go down   Fuel return line into tank Empty Re: Fuel return line into tank Tue Apr 23, 2019 6:23 pm
brickrider2
brickrider2
Well, that wasn't as easy as I had hoped.  Portal tab has no tech section.  Forum tab has "tech, repair and trouble shooting". However, I failed to locate a misc. tab or service bulletin tab.
Where did I make a wrong turn?
1996 K1100LT
5Back to top Go down   Fuel return line into tank Empty Re: Fuel return line into tank Tue Apr 23, 2019 10:13 pm
brickrider2 wrote:Well, that wasn't as easy as I had hoped.  Portal tab has no tech section.  Forum tab has "tech, repair and trouble shooting". However, I failed to locate a misc. tab or service bulletin tab.
The Portal tab when clicked has a link line reading K100 Forum Tech Page. Click on it. What you get will have a Miscellaneous section. Look in it for the link line indicated in the image I posted. Click on it.
6Back to top Go down   Fuel return line into tank Empty Re: Fuel return line into tank Tue Apr 23, 2019 10:16 pm
Stumpy
Stumpy
[url=http://www.kforum-tech.com/Downloads/K100-service-bulletins-and special-tools/bulletins.htm]http://www.kforum-tech.com/Downloads/K100-service-bulletins-and%20special-tools/bulletins.htm[/url]
7Back to top Go down   Fuel return line into tank Empty Re: Fuel return line into tank Tue Apr 23, 2019 10:37 pm
8Back to top Go down   Fuel return line into tank Empty Re: Fuel return line into tank Tue Apr 23, 2019 11:06 pm
brickrider2
brickrider2
Okay, I found it.  Sorry for being such a dunderhead....
1996 K1100LT
