1Back to top Go down   Dry test fuel pump Empty Dry test fuel pump Mon Feb 05, 2024 9:23 pm
tinyspuds
tinyspuds
Hi all,
I want to install a used pump into a tank. I’ve been told the pump works but would obvs like to test that it spins before installation.
Do I have to set up a ‘wet’ environment or can I risk a short dry burst of 12v to check?
TIA, S
2Back to top Go down   Dry test fuel pump Empty Re: Dry test fuel pump Mon Feb 05, 2024 9:34 pm
I've dry run fuel pumps many times. No issues. It doesn't have to be a quick burst run either. I usually run them for a few seconds.
FYI: The smaller diameter terminal is 12V and the larger diameter terminal is ground.
3Back to top Go down   Dry test fuel pump Empty Re: Dry test fuel pump Mon Feb 05, 2024 10:50 pm
tinyspuds wrote:Hi all,
TIA, S
I had an issue last September and had a fuel pump that was known to work as in I took it out of another K and it was working fine. However when I swapped it in it had issues yet tested perfectly. I ended up putting a brand new one in.... www.tills.de was my source. If the tank inners are all original then the terminals can only be connected correctly. You need a 7mm and 8mm spanner for them. Be sure to have the pump pushed all the way home in the mounting damper.
4Back to top Go down   Dry test fuel pump Empty Re: Dry test fuel pump Mon Feb 05, 2024 11:12 pm
tinyspuds
tinyspuds
Thanks to Duck and Olaf. Quick response much appreciated.
Stu
5Back to top Go down   Dry test fuel pump Empty Re: Dry test fuel pump Fri Feb 09, 2024 9:55 am
Obviously, the benefit of a wet test is you know it’s pumping, not just spinning. But spinning (dry) is a great first test.
 I successfully wet tested one of mine previously using some spare hose and a small container of petrol…just make sure the electrical connections are tight (not sparking) and, need I say it(?), test well away from any ignition sources!! No prizes for burning the house down.
Dry test fuel pump Uk-log10 Dry test fuel pump Sco-lo15
                              Paul  Dry test fuel pump 905546712
6Back to top Go down   Dry test fuel pump Empty Re: Dry test fuel pump Fri Feb 09, 2024 10:28 am
Born Again Eccentric wrote:Obviously, the benefit of a wet test is you know it’s pumping, not just spinning. But spinning (dry) is a great first test.
My used one had been running fine but as precaution I replaced it with a new one because I was getting them cheap as in about €40. The used one tested fine, ran fine, pumped fuel but it just wasn't getting sufficient pressure. Problem solved with a brand new one.
I must admit some parts I don't buy used. Fuel pumps, discs, brake bits, switches etc etc
7Back to top Go down   Dry test fuel pump Empty pump test Sat Feb 10, 2024 5:26 am
caveman
caveman
I test them wet with a pressure gauge and valve. Restrict the flow with valve to get 50 to 60 psi and make sure you still have reasonable flow of fuel. If you really want to be confident in the pump put an amp gauge on it as well and make sure it's not drawing more than 6 amps under load.
