1 K1100LT Exhaust System Fri Mar 08, 2019 8:15 pm
brickrider2
In a moment of stupidity I removed the exhaust system from my 1996 K1100LT. I need some advice with refitting it.
The left rear point of attachment is giving me grief. While awaiting the arrival of the four downpipe gaskets, I forgot the proper assembly of this fastener and related parts. I found that I couldn't draw up the pressed steel collar against the rubber grommet when the metal bush is captured within it. I wrestled with it for ages trying to make it all go together as it appeared designed to do. No luck. I had another look at the diagram in the Haynes manual (p. 580) and found the metal bush is shown to be fitted on the starboard side of the pressed steel collar. This makes no sense to me, but it is the only way I could snug up the fastener.
Something is amiss, but I can't work out what. Can someone provide some insight into this?
BTW, if it is not absolutely necessary, don't remove the exhaust system! The Haynes manual skips over this task very quickly, and I've found that it's a real struggle to re-attach if you don't have a number of helpers and a lot of time to burn.
1996 K1100LT
