1Back to top Go down   temerature sensor problem Empty temerature sensor problem Wed Sep 01, 2010 5:02 pm
emilios
Hi
I own a K100RS 1988 and i order from motoworks a coolant temperature gauge sensor..
The problem is that the sensor they send it doesnt fit..i removed the old one and the hole diameter is big for my new sensor.
I someone had the same problem?
2Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Wed Sep 01, 2010 6:18 pm
ReneZ
ReneZ
Which sensor did you order? Without pictures or more info its difficult to respond. You might have received a sensor for the temperature gauge instead of one for the ECU. What did you order?
Rene
BMW K100 - 1985 (0030029) Scotland temerature sensor problem Rain
3Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Thu Sep 02, 2010 7:00 am
emilios
I want to put a temperature gauge on my bike so i order from motorworks a new sensor and temperature gauge...
I took off the old one sensor that my bike has but the new sensor dont fit there..the hole is bigger
Where do you put the sensor for the temperature gauge???
4Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Thu Sep 02, 2010 1:40 pm
emilios
Ok
Problem solved..
I call to the supplier company(motorworks) and they told me that the sensor for the temperature gauge must fit where the drain plug is on the oil/water pump.
5Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Mon Sep 06, 2010 9:57 am
emilios
Ok so i have the temperature gauge sensor and the gauge..all original...
But where to their wires plugged???
Please advice.
6Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Mon Sep 06, 2010 12:05 pm
emilios wrote:Ok so i have the temperature gauge sensor and the gauge..all original...
Please advice.
There is a connector under the tank for attaching the gas and water temp gauges. It is a combined plug that offers wires for fuel transducer, water temperature, power and ground.
temerature sensor problem 12
This connector is usually extended to the front of the fairing using an
extension cable that splits the connections appropriately --
61121459488 "WIRING ADDITIONAL INSTRUMENTS (from 04/85)" -- Part 8 in the diagram above. The water
temperature plug's (part 7 above) signal is fed to the wiring harness using an extension
cable -- 61121459511 WIRING ADDITIONAL INSTRUMENTS (from 04/85) -- Part 9 above.
Below is a photo of the under-tank combined connector:
temerature sensor problem 010anno
This is a photo of the extension cable - gauge ends:
temerature sensor problem 012anno
Good luck.
7Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Mon Sep 06, 2010 3:10 pm
In the download section you can find this document. This is in German but the graphics will help
temerature sensor problem Frog15temerature sensor problem Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
8Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Mon Sep 06, 2010 6:09 pm
emilios
Ok
So on the picture i have 4(temperature gauge), 9 and 7 but i dont have 8..
Now what can i do??
I also found the connector under the tank for the gauges..but i didnt find the connector for number 9.
Can i fit the temperature gauge without number 8?? just to connect the wires with the correct color??
9Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Mon Sep 06, 2010 7:57 pm
ReneZ
ReneZ
Normally the temperature gauge is privided with its signal from the sensor with a separate wire which is then connected with the additional wire loom for the gauges, with the other part of that loom connected to the connector under the tank.
I have a temp gauge fitted with a wire I fitted myself, from the sensor to the gauge, whilst taking the power, ground and light from the "under-tank-connector". Hope that helps.
Rene
10Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Tue Sep 07, 2010 11:33 am
emilios
Ok so thats the foto of the additional wire loom for gauges..i hope..
and a foto of my gauge.
Now im not planning to put a fuel level gauge so i will cut the wires and connect straight to the gauge??
But i still didnt understant where to fit the wire that coming from the sensor.???
Also there are 2 green wires on the loom to the same hole.???
[img][/img]
11Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Tue Sep 07, 2010 11:48 am
emilios
[img]url=https://servimg.com/view/15150802/14]temerature sensor problem Sdc10412[/url][/img]
12Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Tue Sep 07, 2010 11:48 am
emilios
[img]temerature sensor problem Sdc10413[/img]
13Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Tue Sep 07, 2010 7:37 pm
reg_K100RS
Emilios
On the 4 way plug under the tank.
The brown is ground
green/black is supply to gauges
grey/blue is supply to lights on gauges to bring them on with lights
the yellow is the wire to the fuel tank sender
the coolant sender goes straight to the gauge
If thats your temperature gauge in the picture, I'd say the yellow is the one to connect
to the temp sender.
14Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Wed Sep 08, 2010 4:45 pm
ReneZ
ReneZ
Fully agreed!
Rene
15Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Sun Sep 12, 2010 9:51 am
emilios
16Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Thu Sep 16, 2010 6:26 pm
I started to clean my computer and I found this schematic buried among another 1000 files. Don't ask me where it come from and for how long I had it.
Yes I am a pack rat when it's about the K bike.
temerature sensor problem Gauges10
17Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Thu Sep 16, 2010 9:14 pm
Hey Crazy Frog, where did this come from and how long have you had this?
18Back to top Go down   temerature sensor problem Empty Re: temerature sensor problem Sat Sep 18, 2010 11:25 am
ReneZ
ReneZ
It looks like the schedule for the special bridge part in way of the screen, that holds the two gauges and the cigarette lighter plug.
Rene
