1Back to top Go down   Hello from Savannah, Georgia! USA Empty Hello from Savannah, Georgia! USA Wed 19 Dec 2018, 14:38
lefthander
lefthander
Hello,
 My name is John and I am getting back my 1992 K75 that I gave to my son 6 years ago. It's a standard K75 that I'm working on turning it into a K75T.
  Peace,
  John Young
Last edited by lefthander on Wed 19 Dec 2018, 14:55; edited 2 times in total (Reason for editing : Wrong word used)
Greetings John welKome to the Knuthaus
lefthander
lefthander
Thank you so much!
Hello from Savannah, Georgia! USA 177912
lefthander
lefthander
Thanks Dai. I've read several of your posts.
Gr-Racing
Gr-Racing
welcome fellow K75 owner in SAV
Welcome!  Keep us posted on your progress.  I enjoy following these restorations, always lots of good ideas and problem solving.
8Back to top Go down   Hello from Savannah, Georgia! USA Empty k75 return to life Sat 22 Dec 2018, 09:32
lefthander
lefthander
Well I drained the 3year old gas from the tank last night and found the fuel pump vibration dampener? almost completely dissolved. I'm not sure what direction to go. Not sure if I should replace with an aftermarket pump or see if the original fuel pump works and find another vibration dampener. If someone here has gone thru something similar I would appreciate any guidance. Also if someone has any info or pictures on the hose placement inside the tank that would be great. I pulled out a couple of deteriorated fuel lines out and not sure how to put everything back together correctly. On a positive note bled the front brake and had to dismantle the rear brake master cylinder and clean it out to get the rear brakes up to par. Both brakes seem to work perfectly now.
     Peace
