1Back to top Go down   Hi from Melbourne  Empty Hi from Melbourne Sat Nov 24, 2018 10:30 pm
Hman89
Hman89
Hi all!
Looks to be a really group on here!
Id been looking for a motorbike project for quite some time when i found a rundown 86 K100 for $300. I figured any BMW for that pri ce you dont ask questions and buy it regardless.
It had a horrible lime green paint job and looked like it had been sitting in a paddock for years.
The guy had advertised it as suited for parts as it clearly was far from running and missing a few bits and pieces.
6 months on and ive got get it to the point its nearly starting. Few remaining gremlins that ill be looking for some help on and sharing my experience of it on the way.
Hayden
2Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sat Nov 24, 2018 11:47 pm
welcome Hayden
have fun with it
lots of stuff in the how- to's  section
good luck
3Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 12:39 am
Hman89
Hman89
Thanks Charlie,
Has been on of the nicest engines ive worked on, will be starting a build thread shortly
4Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 1:45 am
Welcome to the asylum. The Brick engines are probably one of the most bullet proof engines BM ever built. It is worth going over all the electrical connectors and cleaning them with a product called DeoxIT or similar. I go one step further and smear heavy silicone grease around the connectors. The theory is it will keep out water and air that leads to corrosion. It's been working for over 20 years with the only failure been the one connector that was too hard to get to. There is one problem connector that seems to pop up more than others, it is the four pin connector that supplies power to the fuel pump. It resides under the righthand side of the tank, it is the first port of call if power to the pump is lacking.
5Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 3:24 am
Not surprising that you were able to get it running.
These K motors are bulletproof and will probably still be running long after mankind has become extinct. Only two things will be alive then.  K bikes and cockroaches.
Good on you for bringing one back from the dead. Very Happy
6Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 4:16 am
Hman89
Hman89
Good tip Martin, ive noticed that the tank connector on mine seems a bit of a loose fit. Wouldnt be surprised if it rattled loose at some point. Will need to sort something out for it in the near future.
7Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 4:24 am
Hman89
Hman89
Unfortunately its not quite running just yet duck. Its turning over and firing but she wont run on her own accord yet.
Certainly not wrong about them being bullet proof! I was amazed at the condition of cyclinders on a bike that has early done 150k + kms!!
8Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 4:32 am
A lot of inmates replace the 4 pin connector with a waterproof one. Jaycar is one source.
Regards Martin.Hi from Melbourne  Durate10
Hi from Melbourne  Durate12
Hi from Melbourne  Durate11
9Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 4:37 am
Hman89
Hman89
Perfect! Will be changing it for sure. The whole wiring harness needs a bit of attention really. Have got some loom tape and braided cable on order at the moment to tidy it up.
10Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 5:05 am
How do you know what the cylinders look like?  Did you take the cylinder head off?
11Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 5:21 am
Hman89
Hman89
The whole bike was covered in dirt and what looked like sand when i bought it. With the throttle bodies off i could see seem of it had made its way inside the motor so took the cyclinder head off to clean it up. The top of cyclinder one looked a bit pitted but relapped the valves so looks like everything is sealing as it should. Replaced the head gasket as well of course
12Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 5:32 am
Hman89
Hman89
Hi from Melbourne  20180710
13Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 6:14 am
after  a relap job ...might be worthwhile measuring clearances between camshaft and valve shims ...one of the issues on these bikes is that they can  run too tight on the shims ...a relap will just make it worse    aim for something like 6-8 tho on inlets and 8-10 tho on outlets to start with
whilst cold not an issue   but just be aware
often the pump is the issue as stated before   either the connector or actually the pump could be seized ….before going any further aim to replace all fuel lines inside and outside the tank
good luck
14Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 6:27 am
Hman89
Hman89
Thanks Charlie, good to know! I havent checked the clearances yet but will have to get back to it.
I have replaced the fuel pump on it, bench tested the old one and it was seized. Have also replaced the fuel filter, fuel lines, pressure regulator, fuel rail and injectors (3/4 were blocked, still hoping they might come good for spares if i soak them long enough).
Its getting fuel and spark but not still running. Am picking up a compression tester this week to check the compression
15Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 10:17 am
Low compression after a long nap?  Try this:
https://www.youtube.com/watch?v=DerHlx-bO0s
Marvel Mystery oil is great for loosening stuck rings.  I have used it and it freed up stuck oil control rings that were allowing a lot of oil usage.
http://www.marvelmysteryoil.com/
16Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 9:58 pm
Gryph Marvel is not available in OZ but can be purchased from the US. Cost approx. $15.00 Au for 16 oz plus $32.00 for freight approx. $21.00 Au for 32 oz and $50.00 Au freight approx.
17Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Sun Nov 25, 2018 10:21 pm
That's a shame.  It did a very good job of freeing up my oil control rings.
18Back to top Go down   Hi from Melbourne  Empty Re: Hi from Melbourne Mon Nov 26, 2018 6:51 am
Hman89
Hman89
I put a bit engine oil down the cylinders a few weeks ago but i also had s few other fuel problems then too. Might have a look into a similar product here in Aus and try again.
