1Back to top Go down   K100rs 16v won't start Empty K100rs 16v won't start Tue Nov 20, 2018 4:50 pm
Dympo
Dympo
Hi everyone,
I come here for a little help from you all..
Hey everyone.
I own a 1990 K100rs 16v (ABS, Motronic 2.1, European).
The other day, as I was going to work, the bike suddenly slowed down and eventually couldn't start again. Ignition would start, but there wouldn't be enough power to move anymore, until it stalled completely.
So back to the house, I opened it up and check the spark plugs. They were used but okay, but with a little test it showed that only 2 of them were working and giving a spark.
I got some hints from the web that the issue was coming from the HES. I changed both sensors, and though I now have 4 sparks (and the old sensors were working, having tested them), I still have the same issue..
Here is where I am after working on it for the whole weekend :
- Checked Hall Sensors + all the cables to Motronic box: everything OK
- Diagnosed Motronic box (2.1) : I get signal 1-1-3-3 which is the lower hall sensor, even though it is working.
- Checked all spark plugs : 4 sparks + they get wet
- Checked every fuse
- Checked all injectors : work indivudually, get proper electric signals
- Checked injectors+ramp with ignition : get 4 nice squirts of fuel
Still same symptoms : ignition works but coughs and blurts, air sounds + a tiny bit of smelly white smoke every now and then coming from somewhere around the injectors (?).
I am thinking : hall captors (so, timing) are OK until Motronic. Injection is OK. So sparks are supposedly happening at the right time, and fuel too. Could there be a problem coming from the air? Too much or not enough air going to the cylinders making the explosion impossible? Is there any sensor linked to this that could be the cause?
Or can the Motronic unit itself be the cause of my problems?
Ideas and explanations highly appreciated, as I am completely stuck now!!!
2Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Tue Nov 20, 2018 5:14 pm
I think you could be on to something with the air flow into the cylinders.  The air signal for the mixture is from the throttle position sensor at the rear end of the throttle bodies.  Unlike the unit used with the Jetronic this one does not have on/off switches but is a potentiometer that reflects throttle opening.
There is a procedure for setting and checking the closed position signal from the sensor.  If you have the fault code instructions, this test should be with them.  If I recall, it involves grounding a pin on the diagnostic plug and opening and closing the throttle while watching the temperature light on the instrument cluster.
It is also possible that something is causing the mixture to be too rich and flooding the engine.  If this is the case, cranking for about 5-10 seconds with the tank connector unplugged will cause the engine to fire once or twice as the excess fuel is pumped out and the plugs dry off enough to spark,
3Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Wed Nov 21, 2018 7:28 am
I had a similar issue on mine and it turned out to be the ignition switch. I was able to short out the ignition switch (removed the ignition switch plug from the loom and shorted the two pins togeter that provde ignition power). Bike started straight away.
K100rs 16v won't start Ir-log10
 ;BMW; K1200RS Red
4Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Wed Nov 21, 2018 9:29 am
How long have you owned the moto? How many kilometers are on the odometer? When was its last tuneup? What is the condition of the crankcase breather connected to the air box? What are the compression values for the cylinders?
5Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Thu Nov 22, 2018 12:14 pm
Dympo
Dympo
I have owned it for about 3 years now, have been all the way to Indonesia with it!
Around 78000 kilometers on the odometer, was tuned up at ~45000 kms.
The breather seems to be alright, no sign of a crack or anything.
I just ordered the tools to check compression, will post next weekend or sometime next week!
6Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Sun Dec 02, 2018 6:18 am
Dympo
Dympo
Alright guys, I tested the compression this morning, as well as TPS.
TPS is fine and properly set.
Compression on the other hand, is very strange :
Cyl 1 : ~60 PSI
Cyl 2 : ~80 PSI
Cyl 3 : ~150 PSI
Cyl 4 : ~110 PSI
We're onto something here, but I don't know what.. The engine is still quite young, and I would find it very weird that the valve clearances just all got wrong at the same time..
What could be the issue here?
7Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Sun Dec 02, 2018 6:50 am
Cyl 1 : ~60 PSI
Cyl 2 : ~80 PSI
Cyl 3 : ~150 PSI
Cyl 4 : ~110 PSI
Can you verify that the valve clearances were checked a 45,000 km?
There are several conditions that can produce readings like those—damaged valves or valve seats, failing valve seals, among others. A head gasket leaking between adjacent cylinders can give readings like those on cylinders #1 and #2. A flawed testing technique could produce inconsistent results like these, too. Describe exactly how you performed the compression test and the type of equipment used.
8Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Sun Dec 02, 2018 7:09 am
Dympo
Dympo
Hmm apparently it was not checked at 45'000.
As for the compression test :
- Removed all the spark plugs and unplugged the coils
- Unplugged the fuel pump relay to avoid too much fuel being injected in the cylinders
- Used a compression kit, plugged in the spark holes one by one, ran the starter a few times (3-4 impulses) with throttle fully open
9Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Sun Dec 02, 2018 7:12 am
Take the fuel filter out and see if you can blow through it in the direction of the arrow.
10Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Sun Dec 02, 2018 7:52 am
Dympo wrote:- Used a compression kit, plugged in the spark holes one by one, ran the starter a few times (3-4 impulses) with throttle fully open
Does the compression gauge screw into the cylinder or must it be pushed into the opening then held in position during cranking?
11Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Sun Dec 02, 2018 8:35 am
Dympo
Dympo
duck wrote:Take the fuel filter out and see if you can blow through it in the direction of the arrow.
Will try next time I work on it. What's the thought behind it?
It screws into the cylinders, same size as a spark plug so no loss of air here
12Back to top Go down   K100rs 16v won't start Empty K100rs 16v won't start Sun Dec 02, 2018 9:42 am
norton71
norton71
do a wet and dry compression test
13Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Sun Dec 02, 2018 9:51 am
Dympo wrote:It screws into the cylinders, same size as a spark plug so no loss of air here
Ok.
Right now, as norton71 indicates, you could repeat the compression test using a spray of oil in the cylinders to determine if piston rings are involved in these low numbers. You could check the valve clearances of C1 and C2. Tight exhaust clearances might indicate failing valve components are contributors to this problem. You could do a leakdown test attempting to locate the source of the problem.
Because it happened suddenly, because the compression is similarly low in adjacent cylinders compared with the others, and because difficulty in starting followed, I'm tending to believe a head gasket breach is causing this. That would be the most benign cylinder head condition to repair in terms of cost and labor. To my knowledge, it isn't a common failure in K engines.
Have you ever flushed the coolant system and replaced coolant? Have you had the temperature warning indicator glow intermittently during your travels or recently?
14Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Sun Dec 02, 2018 10:12 am
Dympo
Dympo
Thanks for your insight, Laitch. I will try and check the valve clearances next week if I can... And try the spray of oil too.
What do you call a leakdown test?
I have flushed and replaced coolant a couple of years ago when I changed the radiator, and never had the temperature warning indicator flash.
I've also had ABS issues for a long time now, light keeps flashing, but I don't think those issues are related : being running with ABS light on for at least 20000 kms now.
15Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Sun Dec 02, 2018 10:19 am
Dympo wrote:What do you call a leakdown test?
This article was the first hit in a Google search for leakdown test. It sums up the procedure and its intent.
16Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Sun Dec 02, 2018 3:30 pm
It is very important that you earth the spark plug leads while doing the compression test. Failure to do so can lead to damaging the ECU. K100rs 16v won't start 161205
17Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Sun Dec 02, 2018 6:14 pm
The thought is that it's hard for a motor to run well if it's not getting enough fuel.
I can't tell you how many people I've come across who tear their hair out over a K not running well and then when I tell them to check and/or replace the fuel filter that clears everything up.
And since it's so easy to check it's a good diagnostic starting point for an engine that's not running well.
18Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Wed Dec 12, 2018 2:42 pm
Dympo
Dympo
Quick question, guys.
I've been pondering lately. I might be better off just getting a new engine, since I cannot seem to figure out what the issue is and I have seen pretty good deals not too far away from home (around 250 usd for a 50'000 kms engine).
How many different types of engines are there, and are they all compatible? I found a K100 '84 engine, could it fit my bike?
19Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Wed Dec 12, 2018 4:40 pm
For a K100RS4V you need an engine from a K1 or another K100RS4V.
The 84 is a 2V motor with a different electrical system that runs on an ICU and L-Jetronic as opposed to the Motrtonic with no ICU that a K100RS4V runs on.
20Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Wed Dec 12, 2018 5:07 pm
Dympo wrote:
. . . I cannot seem to figure out what the issue is . . .
Does this statement mean that you have done both the leakdown test and the valve-clearance check but results were inconclusive?
21Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Thu Dec 13, 2018 6:55 am
Dympo wrote:Alright guys, I tested the compression this morning, as well as TPS.
Cyl 1 : ~60 PSI
Cyl 2 : ~80 PSI
Cyl 3 : ~150 PSI
Cyl 4 : ~110 PSI
I am with the comments on head gasket between 1 and 2......but then 4 is also slightly low and makes me wonder.
But even before going into the head gasket be fully sure the compression test is correct, even to the point of getting someone else with different kit to do it. As it stands the readings don't give me confidence if that was my K that they were all correct, I would still have a second opinion on it.
Then go check the valve clearances as they can cause this too.
All being well a head gasket is not a major task, access is good.
22Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Thu Dec 13, 2018 12:46 pm
Did you shoot a few cc's of oil in the cylinders when you did the test, and then hold the throttle fully open while you cranked for about 4-5 seconds?  I always pull all the spark plugs when I do compression tests.  A little bit of oil helps to bring the compression up in engines that have been sitting idle for long periods.
23Back to top Go down   K100rs 16v won't start Empty Re: K100rs 16v won't start Thu Dec 13, 2018 2:00 pm
mike d
Point-Seven-five wrote:  A little bit of oil helps to bring the compression up in engines that have been sitting idle for long periods.
And if it doesn't then suspect a valve/valve seat issue.
Mike
