1Back to top Go down   missing thrust ring?.. Empty missing thrust ring?.. Sat Oct 06, 2018 3:47 am
73MOH
73MOH
Hi everyone.. I started putting my k1100 back together today (rear main), and immediately ran into a problem...
I don't appear to be in possession of part no. 2 in the diagram..(thrust ring).. I may have lost it, but I don't remember seeing it on dissassembly.
I've had a look online and can't see one for sale.... The picture isn't very clear, but I suspect it's just a cylinder shaped part that sits between the nut and oring that locates the oring.... If anyone knows where I might  find one it would be much appreciated.
missing thrust ring?.. K1100_10
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
2Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 06, 2018 4:57 am
ive seen them on motobins  and motorworks sites
so I guess the guys in western aussie have them also , ?? munich motorcycles ?
don't think they were a whole lot of money either
grahame jays , kbike beeemer bits  in eden listd them as available secondhand  for $3.00
https://kmodelbeamerbits.com.au/bmwk-seriesshop.html#!/Clutch-&-Actuation/c/12301078/offset=9&sort=normal
but if I search tomorrow may have one here?
3Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 06, 2018 5:14 am
73MOH
73MOH
Thanks Charlie.... thats perfect, will order.
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
4Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 06, 2018 6:29 am
My guess is if you did not have the thrust ring originally, if would not have worked as intended; major 'sloppage' (an apt word) would gave been evident.
5Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 06, 2018 6:50 am
73MOH
73MOH
Two Wheels Better wrote:My guess is if you did not have the thrust ring originally, if would not have worked as intended; major 'sloppage' (an apt word) would gave been evident.
Hmmm, I will turn my garage upside down tomorrow...
is it alloy? or steel?.....
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
6Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 06, 2018 7:21 am
It's hard steel, less than 5mm thick, and has a slight flange to it.
7Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 06, 2018 7:57 am
about the same size as a 20 cent piece mate , and definitely magnetic
missing thrust ring?.. 20181018
 hope you find it , good luck
8Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 06, 2018 8:41 am
It doesn't seem as large as the diagrams imply. It's probably hidden in plain sight. Smile
9Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 06, 2018 6:13 pm
73MOH
73MOH
thanks guys....
on a separate note,in the manual it says....
• Coat tapers in clutch housing with Optimoly MP 3 or similar
are they talking about the spline when they say tapers?
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
10Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 06, 2018 6:22 pm
73MOH wrote:are they talking about the spline when they say tapers?
I should think so unless you find candles within the housing. Smile Who is they anyway; which manual is this?
11Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 06, 2018 8:02 pm
73MOH
73MOH
I found it Very Happy
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
12Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 06, 2018 8:05 pm
yay !!!!  missing thrust ring?.. 112350
13Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 06, 2018 8:08 pm
Goodonya! That makes life a bit easier.
14Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Fri Oct 19, 2018 10:41 pm
73MOH
73MOH
I'm hoping to finish this today and finally go for a ride....  Very Happy
Can someone tell me where the main, thick earth cable connects to?... It sees to head  towards the abs mount.(abs 2 system), but it seems to me one of the starter mount bolts would be a better earth....
thanks Paull
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
15Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 20, 2018 2:38 am
Just above the coils onto the gearbox case 6mm Allen head bolt
16Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 20, 2018 4:20 am
73MOH
73MOH
RicK G wrote:Just above the coils onto the gearbox case 6mm Allen head bolt
Thanks Rick.... do you mean the boss on the gearbox about 3" above the shifter?... My computer earths are long enough to get there, but not the main battery earth, although I have now added another cable from the abs mount to that boss for the battery...
and I've just started it up (still on hoist) and tested the clutch etc. and all seems well.... got a couple of little things to stitch up in the morning and I'll be going for a ride Very Happy Very Happy Very Happy
Paul
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
17Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 20, 2018 6:43 am
Paul
Yep that's it (must be the shit I am smoking) Very Happy
18Back to top Go down   missing thrust ring?.. Empty Re: missing thrust ring?.. Sat Oct 20, 2018 6:53 am
good to hear Paul
hope tomorrows ride goes well
