Number of posts : 11701
hi graemem
you have checked the oils in both the bevel box and gearbox ?
might be worth a look at the universal joint on the drive shaft ...and the lubrication of the splines both ends of the drive shaft also .
also check the pinion shaft for moovement (for - aft ) my previous one had about 2 - 3 mm moovement allowing the pinion to moove off the big diffgear ...and of corse oil leaks at the input bearing of the bevel box .
i dont have a lot of history regarding the output bearings of the gearbox ..but could be worth a thought . look for any oil leaks around that area .but the rubber boot that joins the swingarm to g/box would hide that from view .
