1Back to top Go down   Trailer on K1100LT Empty Trailer on K1100LT Mon Feb 04, 2019 10:50 am
I have finally got a trailer, at this moment coming across the Irish Sea courtesy of a friend.
I have a towbar collected at K Fest and it came wired with a 7 pin socket which I will not be using.
Looked at the wiring and ok with that but looking for advice on plug connector between modified bike wiring and trailer. It will be used in all conditions and therefore needs weather resistance. I would like to use on of the marine type plugs that have a sealing ring which is screwed to clamp the plug together against the seals. Any thoughts?
Trailer on K1100LT Olafs_10
Trailer on K1100LT 49769210
2Back to top Go down   Trailer on K1100LT Empty Re: Trailer on K1100LT Mon Feb 04, 2019 12:46 pm
Don't over-egg the cake Olaf. Those seven pin plugs are fitted to millions of cars and vans and do the job day in, day out. If anything goes wrong, they're easy to get hold of.
3Back to top Go down   Trailer on K1100LT Empty Re: Trailer on K1100LT Mon Feb 04, 2019 1:57 pm
When I had a Rigid Inflatable Boat (diving, water skiing, fishing etc) I swore by Bulgin Buccaneer connectors for connecting power and/or coaxial cables to the VHF radio, Fish finder, GPS and magnetometer. I used bulkhead sockets on the boat centre console and plugs on the device cables. Bulgin do all sorts of different inserts to suit many applications and they are waterproof when either connected (plug in socket) or when disconnected, with caps fitted. They made it really easy to fit and remove the devices when the boat was not being used and avoided corrosion of the contacts. Perfect for a very wet, marine environment.
RS stock them in the UK (example of 7 pin version below)
Trailer on K1100LT Buccan10
Trailer on K1100LT Buccan11
However, I'm with Dai for a bike trailer application - use the standard auto trailer sockets and plugs, they are much cheaper and are designed for the wet road environment.
Last edited by Born Again Eccentric on Mon Feb 04, 2019 3:00 pm; edited 1 time in total (Reason for editing : Upload of correct socket picture (rather than 2 pics of plug))
Trailer on K1100LT Uk-log10 Trailer on K1100LT Sco-lo15
                              Paul  Trailer on K1100LT 905546712
4Back to top Go down   Trailer on K1100LT Empty Re: Trailer on K1100LT Mon Feb 04, 2019 2:46 pm
I am half with Dai as I have a shed full of those 7 pin fittings mainly because of the car trailer ,no matter what I do wires go wrong as in contacts but I suppose I can do it in my sleep.
I like the marine fitting for another reason, they work and being non standard is a slight disincentive to someone else hooking it up and going off with it.
Mind you the difference would buy a nice Claret.........
5Back to top Go down   Trailer on K1100LT Empty Re: Trailer on K1100LT Tue Feb 05, 2019 8:07 am
BobT
BobT
92KK 84WW Olaf wrote:I like the marine fitting for another reason, they work and being non standard is a slight disincentive to someone else hooking it up and going off with it.
Not sure that you are worried about something that is not going to happen. Can't see any car driver wanting to tow a shoe box around and no other biker would be seen dead towing that thing. :-)
6Back to top Go down   Trailer on K1100LT Empty Re: Trailer on K1100LT Tue Feb 05, 2019 9:29 am
No worries BobT I had not been planning to put anyone in it.....
7Back to top Go down   Trailer on K1100LT Empty Re: Trailer on K1100LT Thu Feb 07, 2019 6:30 pm
92KK 84WW Olaf wrote:No worries BobT I had not been planning to put anyone in it.....
The only bodies in there will be dead ducks, probably in confit form! lol!
Trailer on K1100LT Ir-log1188....May contain nuts!Trailer on K1100LT Ir-log11
K75RTP - 1994
