1Back to top Go down   Throttle Body Vacuum Variation Empty Throttle Body Vacuum Variation Fri Sep 28, 2018 12:36 pm
Bunyak100
Bunyak100
i have measured the 4 throttle baby vacuums and compared and I find that #2 is wY higher than the rest and seem to be unable to adjust screws to sync, I have checked with a spray of engine start and also propane, check the rubbber as best I can.
Any ideas please
I have also just complete a valve clearance check and all are ok
2Back to top Go down   Throttle Body Vacuum Variation Empty Re: Throttle Body Vacuum Variation Sun Sep 30, 2018 2:30 pm
The passage the air screw controls is probably blocked.  Try removing the screw and shooting carb cleaner in there.
3Back to top Go down   Throttle Body Vacuum Variation Empty Re: Throttle Body Vacuum Variation Sun Sep 30, 2018 5:01 pm
or a pipe cleaner soaked in carb cleaner, through them all
but the feed passage to the valve could be blocked as .75 suggests
