1Back to top Go down   Greeting from Norway Empty Greeting from Norway Fri Jul 13, 2018 10:21 am
k100_norway
k100_norway
Mandatory to present myself..
I am a 55 year young man from the middle of Norway and i just bought a K100RS 1986 model. the bike is in good condition, with 165000 km on the meter but there are som issues and i thougt this forum woul be at good help.
I work with my hands and do most of the work on the bikes myself.
Like blues, beer and a good movie when i am not riding.
2Back to top Go down   Greeting from Norway Empty Re: Greeting from Norway Fri Jul 13, 2018 8:36 pm
WelKome from Australia. Ask as many questions as you want and we will answer them all. Greeting from Norway 177912
3Back to top Go down   Greeting from Norway Empty Re: Greeting from Norway Fri Jul 13, 2018 10:55 pm
WelKome!
At those kms it's still got plenty of life left in it.
You came to the right place to help you maintain it.
4Back to top Go down   Greeting from Norway Empty Re: Greeting from Norway Fri Jul 13, 2018 11:03 pm
Welcome, k100_norway, to the most gentlemanly K forum on the interwebtrons. Here you'll find all manner of savoury and unsavoury characters, some of whom can offer sound advice, some who will, some who won't, and possibly even some who shouldn't*. Did I just write that out loud?!
I'm reminded of a favourite radio station when I lived in the NE of the USA many years ago. Their slogan was "Some songs you like, some songs you don't."
Greeting from Norway 652573
*tongue planted firmly in cheek.
k100_norway
k100_norway
I have a problem with the neutral light an gear display. The lamp is always green and the LCD shows only a dot. i have checked the contact on the right side, under the side cover and tried to make contact between two of the wires whil running, the engine stops, as it should do, so it does when i put it in gear with the side stand down. I am puzzeling with the thoug of dismantling the dashboard to see if it is the connection behind it thas is troubling me. Are the display broken i have to replace it, anyone?  Greeting from Norway 652573
6Back to top Go down   Greeting from Norway Empty Re: Greeting from Norway Mon Jul 16, 2018 5:56 am
Markosaurus
Markosaurus
Welcome to the forum.  Plenty to do here.
;BMW; K75RT “Lil’ Blue”
7Back to top Go down   Greeting from Norway Empty Re: Greeting from Norway Sun Aug 26, 2018 10:02 am
Brickler
Brickler
You have some seriously awesome roads around there, and the scenery…!  cheers
K100RS ABS 1990
8Back to top Go down   Greeting from Norway Empty Re: Greeting from Norway Sun Aug 26, 2018 4:28 pm
k100_norway wrote:I have a problem with the neutral light an gear display. The lamp is always green and the LCD shows only a dot. i have checked the contact on the right side, under the side cover and tried to make contact between two of the wires whil running, the engine stops, as it should do, so it does when i put it in gear with the side stand down. I am puzzeling with the thoug of dismantling the dashboard to see if it is the connection behind it thas is troubling me. Are the display broken i have to replace it, anyone?  Greeting from Norway 652573
Hjertelig velkommen K100-norway.  It's probably not your instrument cluster, rather it is probably the gear indicator switch on the transmission.  Try to disconnect the switch from the cluster (the connector is found on the right side of the frame, just below the battery cover, probably tie-wrapped to the lower frame).  You can follow the lead to where it emerges from below the battery; then you know it is the right connector.  The neutral light should extinguish and the LCD will probably still show only a dot.  It sounds like the display is toast (gone bad).  I've designed a LED replacement but its still in the prototype stage.
9Back to top Go down   Greeting from Norway Empty Re: Greeting from Norway Sun Aug 26, 2018 7:48 pm
WelKome, k100_norway.
I spent 2 weeks in Norway recently and it is indeed a beautiful place. I even travelled not far from you when we were near Trondheim, going to Hell and back. On 4 wheels, not 2, sadly.
Robmack is very likely correct about the problem being the switch on the back of the transmission.
Fortunately, with care they are usually easily dismantled, cleaned and reassembled. Make sure you seal it well, as the original seal breaking up and letting water in is likely the cause of the problem.
The bad/good news is that the switch is difficult/impossible to get to without removing the swing arm that carries the drive shaft. The good part of that is that while its apart is a good time to check and lubricate the drive shaft spline - always a good thing to do when you get a K bike.
Enjoy the ride.
