1Back to top Go down   Footpeg Lowering Kit Question. Empty Footpeg Lowering Kit Question. Sat Aug 04, 2018 2:49 am
blueeyedogre
blueeyedogre
I've been searching the net for footpeg lower kits and I can find lots for newer BMW's but nothing for the old girls. Will the kits for the new bikes fit our old darlings?
2Back to top Go down   Footpeg Lowering Kit Question. Empty Re: Footpeg Lowering Kit Question. Sat Aug 04, 2018 3:11 pm
Unlikely.
3Back to top Go down   Footpeg Lowering Kit Question. Empty Re: Footpeg Lowering Kit Question. Sat Aug 04, 2018 5:36 pm
the k1200 and a few newer versions connect the foot peg via a bolt through the side plates  and then either go up , down etc
the k100 series have cast pivot locations into the sideplate , I guess if you were to grind those off ...you could possibly fit an appropriate location bolt and go from there .
but an issue may be that the sideplate thickness will be too thin  to properly take the weight of a foot peg and rider at the new location
beware the k1200 foot peg mount kits are notoriously expensive
maybe best option might be to make an adaptor plate  out of something seriously decent in size ...perhaps 8 -10mm  aluminium   with 2 sets of mount holes .. the first set of holes for the standard gearbox mounts , the second set of holes for the new location of the entire footplate - and footpeg
just a heads up
plan with parts in hand  before you cut or grind
4Back to top Go down   Footpeg Lowering Kit Question. Empty Re: Footpeg Lowering Kit Question. Sat Aug 04, 2018 10:52 pm
Footpeg Lowering Kit Question. Ir-log1188....May contain nuts!Footpeg Lowering Kit Question. Ir-log11
K75RTP - 1994
5Back to top Go down   Footpeg Lowering Kit Question. Empty Re: Footpeg Lowering Kit Question. Sat Aug 04, 2018 11:05 pm
looks like they will fit all the k bikes Will ...brilliant find
6Back to top Go down   Footpeg Lowering Kit Question. Empty Re: Footpeg Lowering Kit Question. Sun Aug 05, 2018 1:05 am
BobT
BobT
The original question is, in my opinion, quite bizarre. Before asking a question like this I would google a picture of a newer BMW and compare what I see to my bike. It would be easy to see that they are completely different.
As it was my 60th birthday yesterday perhaps I am just being a grumpy old man.  Rolling Eyes
7Back to top Go down   Footpeg Lowering Kit Question. Empty Re: Footpeg Lowering Kit Question. Sun Aug 05, 2018 1:20 am
My question is why would you want to lower the pegs? They'll just scrape on turns.
8Back to top Go down   Footpeg Lowering Kit Question. Empty Re: Footpeg Lowering Kit Question. Sun Aug 05, 2018 7:21 am
If the problem is that you're too tall, and your legs are cramping up? If so why not raise the seat? As stated by lowering the pegs you will definitely reduce your cornering clearance.
9Back to top Go down   Footpeg Lowering Kit Question. Empty Re: Footpeg Lowering Kit Question. Sun Aug 05, 2018 12:35 pm
MartinW wrote:If the problem is that you're too tall, and your legs are cramping up? If so why not raise the seat? As stated by lowering the pegs you will definitely reduce your cornering clearance.
Not only move the seat up but back as well. I have a Russell seat on my LT that does both and works well for my 34" inseam.
10Back to top Go down   Footpeg Lowering Kit Question. Empty Re: Footpeg Lowering Kit Question. Sun Aug 05, 2018 5:44 pm
When I lowered my seat as per Duck I also lengthened the riders seat. As consequence it did shorten the passenger seat. But as I very rarely carry a pillion it doesn't matter and gives me more choice of movement.
11Back to top Go down   Footpeg Lowering Kit Question. Empty Re: Footpeg Lowering Kit Question. Tue Aug 07, 2018 11:00 pm
I found this site on ergonomics:
Cycle-ergo.com. Hip angle is an issue for me especially on the K1 .
After trying many bikes on the site my LT with the bar risers and set back was top of the list.
K75RTP - 1994
