1Back to top Go down   G'day from down under to up over! Empty G'day from down under to up over! Thu Aug 02, 2018 11:25 am
monaro74
monaro74
I have several big bikes, the smallest being an old Kawasaki GPZ900R. I recently purchased an 88 K100RS with 85,000km on the clock. It was imported from Japan and has some unique features.
As with all new mechanical purchases, a major service is needed as a baseline, all fluids, splines and some workto the fuel system.
I'm also after a dummy shaft that can be used to centre the clutch disc before tightening up the bolts. If someone knows where I can get one of those Id really appreciate the info.
Ciao
Justin
Welcome along Justin - you're in good kompany down there, although perhaps a smaller concentration of K owners in South Australia than up along the NSW/Queensland corridor.
Try using the search function for tips on centring the clutch - I recall some chatter about using nothing fancier than a marker pen to help do the alignment; a much cheaper option than buying the bespoke alignment tool that will get used very infrequently.
Enjoy
G'day from down under to up over! Uk-log10 G'day from down under to up over! Sco-lo15
                              Paul  G'day from down under to up over! 905546712
Welcome to the asylum. If you really have to have one and you have access to a metal lathe. The dimensions for making one are around, and are also in the Haynes workshop manual in the clutch section 3.5 drawing 5.7c.
Welkome aboard! Depending on where you are in south Oz keep an eye on the forum for an inmate called Packo who is around Adelaide somewhere and a great K bike enthusiast.
I'm sure you will enjoy the RS - the K bikes are quite different to the Japanese bikes but be warned you do get hooked on them.
welcome aboard
a few f us have used a marker pen to centre the clutch   there is a thread  in the forum that describes it
https://www.k100-forum.com/t1148-clutch-centering-tool#6362
another used a screw driver
here https://www.k100-forum.com/t3585p100-1988-lt-light-renovation#95410
good luck
prince
prince
Welcome from a new member in Canada
Paul
1984 Honda V65 Magna
1985 BMW K100RT
2011 BMW K1600GTL (gone)
2018 BMW K1600GTL
Hi Ya Justin welKome to the forum Knuthaus.
If you need a manual PM me and I can arrange it.
alfinkr
alfinkr
hello im user from Indonesia, K100 87
9Back to top Go down   G'day from down under to up over! Empty Thanks everybody for the warm welcome Thu Aug 02, 2018 10:13 pm
monaro74
monaro74
Thanks everybody.
I recently did the Klutch in my 100 series and Exedy include a plastic clutch alignment tool with the new clutch kit.
Can't say I have ever lined up with a marker pen before but being able to spin the clutch with the tool and reduce any tight spots would certainly be handy.
Looking forward to catching up with some of you blokes and hitting the tarmac.
Justin
