1Back to top Go down   Clock jumps Empty Clock jumps Tue 24 Jul 2018, 11:27
nobbylon
nobbylon
Set my clock a few times now but it jumps to a random time! any ideas folks? thx
2Back to top Go down   Clock jumps Empty Re: Clock jumps Tue 24 Jul 2018, 13:59
Either you are going so fast that you are warping time. Or a bad connection or dry solder joint. Clock jumps 610153
3Back to top Go down   Clock jumps Empty Re: Clock jumps Tue 24 Jul 2018, 14:21
nobbylon,
 You could try this idea that I used to increase the pressure on the contact strips of the liquid crystal display.....it might work!
https://www.k100-forum.com/t4319-clock-repair
4Back to top Go down   Clock jumps Empty Re: Clock jumps Tue 24 Jul 2018, 14:43
Poor connection with Pin 1 on the OEM connector. Might also be a poor connection with the flexible circuit card strip inside the gauge cluster but tackle the Pin 1 problem first.
5Back to top Go down   Clock jumps Empty Re: Clock jumps Tue 24 Jul 2018, 14:46
nobbylon
nobbylon
thanks for the suggestions. Another job to do!
