I am restoring a 1987 K100 RT and have a problem diagnosing the wiring system. I have researched every electrical diagram I can find linked from this forum plus several othe sources, but I have found none that include the alarm/antitheft unit that appears to be an original component in my machine (very well incorporated into the bike's wiring harness). It is marked 'TUV' and has a seat button, plus a keyed switch that is in the relay box left side (and I didn't get a key from the seller as the bike has been sitting for many years). I am getting no voltage to the starter button on the right handlebar, and thereby no activation at the starter relay. Indicator lights on the instrument panel are nonfunctional as well. By jumping the two wires to the alarm switch it does activate the imtermittent horns, but I can't seem to logic the unit's full functionality so I can debug the wiring.
Since I am restoring the bike as an educational venture, I'd like to know how the unit should operate with the 5 wires going to the alarm unit so I can verify it's functionality, or at least how to remove it fully from my bike's system and rewire.
Any help?
