1Back to top Go down   radiator vibration seal needed Empty radiator vibration seal needed Thu May 10, 2018 11:57 am
audibob
audibob
Hi
has anyone got a radiator cover anti vibration seal .
Bob
radiator vibration seal needed 20180514
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
2Back to top Go down   radiator vibration seal needed Empty Re: radiator vibration seal needed Thu May 10, 2018 2:13 pm
I made one from closed cell foam (Neoprene). It's good for relining the fairing 'kneepads' too.
3Back to top Go down   radiator vibration seal needed Empty Re: radiator vibration seal needed Thu May 10, 2018 2:32 pm
46 63 2 312 922 is the OEM part number for the inner rectangular 300mm long 'surround' portions and you'll need 3 of them. 46 63 1 453 980 is the 365mmX8mmX2mm strip. 46 63 1 453 907 is the 'rubber' 305mm long bit at the bottom of the outer shroud, and 46 63 1 453 627 is the 70mm long bit.
Or, get some dense, sponge-like substance and fab one up.
