1 Replacing instrument bulbs 1990 K100lt Thu Aug 09, 2018 11:28 am
SigurdH
I have reached the time (80 000 mls) where one or more bulbs on the right hand side of the instrument panel has stopped working. I have got a new set of 5 (green) bulbs, removed the windscreen in order to loosen the instrument panel, just to find out that it is very little room back there, and that the instrument panel is fastened with hex bolts, which wil take forever to unscrew and put back with my kind of tool.
- Do I have to remove the front panel with the headlight to do this job?
- Do I have to remove the +side of the battery when working on the instrument panel?
- It does not seem possible to remove the two connectors before the panel is loose. Is this corretct? I have understood that the connectors are covered with a lid with one bolt. Can I do this aafter the instrument panel i loosened?
Regards, Sigurd
Regards, Sigurd
