1 Air Leak Fixing help needed Wed May 30, 2018 2:51 am
George_Pap
Good day community.
K100RT resurrection project advances.
After researching the bad/poor idle running issue i did the test as suggested to spray check my injection - intake manifolds area for leaks.
So, what i did.
A. Sprayed some WD40 contact cleaner and found idle stalling when spraying the red marked areas in the picture.
B. Took out the injectors and tested the spray pattern on a paper cardboard. pattern was even and fine.
So. Its certain that i have to fix the leak. And here come my questions
1. Can i replace the Oetiker clamps with common ones?
2. Since i'm there for that fix is there something else i could check to prevent dismantling the whole left side in the near future?
3. Here is the parts list i'm preparing to order. Do i miss anything? Its crucial because ordering from Motorworks UK takes to reach my Island more than 2 weeks. I m thinking that it would be wise to replace all 4 inlets, lower and upper and clips.
4. Is any of these parts interchangeable with any current production part that i could acquire from the local BMW Dealer?
5. Also want to replace the fuel line from the tank in order to expand it a bit longer for easier tank removal. The OEM part dimensions are 8x13 (mm i guess)
I cant find the exact match from 3rd party such as WURTH or KLEBER. The closest i get is 7,5 X 15. Any suggestions?
Thank you once more for the helo.
So, what i did.
K100RT (Early 1985 -nonABS)
