1 K75 speedo down Sun Jan 07, 2018 3:39 am
BooG
It appears my speedo/odometer is not working. I removed the instrument cluster and took off the back. I checked the three pin connector which didn't show any corrosion, so put it back together. I unplugged and put back the connector next to the underseat tray. I removed the rear speed sensor from the final drive, cleaned it and replaced, but still no joy. I have noticed the indicators do not self cancel....does this point to a faulty sensor? Should I try the soldering iron trick?
