2 Re: Neutral Light Tue May 08, 2018 11:42 am
When 2-4 are grounded (from the gear position switch on the back of the transmission) the cluster will light up the N indicator lamp in the cluster and also put out 12V on pin 5 which is a green/black wire that goes to the start button.
3 Re: Neutral Light Tue May 08, 2018 11:53 am
Pins 2 - 4 are inputs, not outputs. As Duck says, the signals present on them represent a code that indicates the gear. Gear "0" is all inputs grounded.
If you have removed the OEM cluster, then you have to have a way to decode the input to produce neutral when gear "0" is selected.
4 Re: Neutral Light Tue May 08, 2018 7:02 pm
DBRMN
Yeah that's what I suspected I hoped it was separate to the whole gear indication. How complicated is the modification and does anyone know a thread where someones attempted it? As I really feel I should have a neutral light, is there a different way you can add one?
5 Re: Neutral Light Tue May 08, 2018 7:04 pm
6 Re: Neutral Light Tue May 08, 2018 9:19 pm
For the UK MOT all you need is:
1. A high-beam indicator
2. An indicator repeater; and only then if you can't see all four indicators at the same time.
What you'd be stupid not to have:
1. A neutral light
2. An oil pressure light (or if you're a Kawasaki: an oil level light. Never did get that one...)
So that covers just about all Britbikes from about 1960 onwards
Sensible-to-have:
1. Anything that gives you an indication of parts of the engine e.g. the generator, fuel level warning (and only that because there's no reserve switch)
Icing on the cake:
1. Anything like the GPI.
But then again, some of the bikes I rode early in my career had no neutral light and no indicators from new. You soon learned where neutral was; or in the case of the Bridgestone rotary gearbox, not to go directly from top to first on a downchange (Rick?).
1. A neutral light
Sensible-to-have:
Icing on the cake:
7 Re: Neutral Light Tue May 08, 2018 9:21 pm
DBRMN
This is probably going to take me a bit to get my head round as I have no electrical knowledge, doesn't look too difficult but that might be me being naive lolduck wrote:Here's one way:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/gpiemulate/gpiemulate.htm
8 Re: Neutral Light Tue May 08, 2018 9:23 pm
DBRMN
Already wired up full beam works a treat, do I need an indicator light if I have handle bar end indicators cause you can literally see them? I plan on wiring a check engine light as well, I have five possible warning lights.Dai wrote:For the UK MOT all you need is:
1. A neutral light
Sensible-to-have:
Icing on the cake:
Already wired up, battery charging light and oil light, is there a way of testing them when your done thought?
Whats a GPI?
9 Re: Neutral Light Tue May 08, 2018 10:03 pm
Gear Position Indicator - tells you what gear you're in - like the LCD in the tach on the factory cluster.
10 Re: Neutral Light Tue May 08, 2018 11:42 pm
Please see Gear Indicator Aftermarket Speedo and Other Circuits . You can get this four relay circuit from me for very cheap, which saves you the bother of building it. My price is about the same as your costs would be.
11 Re: Neutral Light Wed May 09, 2018 11:07 am
DBRMN
Wow this is some clever stuff! I'm definitely interested however it's probably going to be a month till I can focus on this as my EPQ ends in a month so I need to get the rear cowl down but after that I will most likely be in touch thanks you!robmack wrote:Please see Gear Indicator Aftermarket Speedo and Other Circuits . You can get this four relay circuit from me for very cheap, which saves you the bother of building it. My price is about the same as your costs would be.
12 Re: Neutral Light Wed May 09, 2018 11:54 am
I'd fit an indicator repeater. I doubt most MOT testers are aware of that clause in the Construction And Use regulations.DBRMN wrote:do I need an indicator light if I have handle bar end indicators cause you can literally see them? I plan on wiring a check engine light as well, I have five possible warning lights.
The oil light should work if you earth the end at the pressure switch. Battery light - you'll have to wait till start up and check whether it goes out.
Now, list here everything you've done; I want to check that you're not heading into SVA (Single Vehicle Authorisation) territory. That's a whole new ball of wool.
13 Re: Neutral Light Wed May 09, 2018 3:42 pm
DBRMN
Whats an Indicator Repeater? is that what makes it flash?Dai wrote:I'd fit an indicator repeater. I doubt most MOT testers are aware of that clause in the Construction And Use regulations.DBRMN wrote:do I need an indicator light if I have handle bar end indicators cause you can literally see them? I plan on wiring a check engine light as well, I have five possible warning lights.
Wheres the pressure switch?
When you say done to the bike do you mean every modification?
14 Re: Neutral Light Wed May 09, 2018 11:12 pm
The indicator repeater is the amber (sometimes green as on the K) light in the instrument panel that flashes in time with the indicators. Some bikes have two (one for each side, like the K) and some have only one. If you fit one for each side then you run the same coloured wire for that side to the repeater bulb and earth the other side of the repeater. On a K that's a blue/black wire for the right side and a blue/red wire for the left side. For a single repeater bulb, you would connect the K blue/black wire to one side of the bulb and the blue/red wire to the other side of the bulb. On the face of it that should not work because you appear to be feeding two positives to the indicator repeater. In operation, only one side gets 12 volts (the side that is flashing) and the other side earths through the non-flashing bulb filaments. If you're doing any form of physics, your tutor can give you the lowdown on the whys and wherefores of it working.
The oil pressure switch is the brown/green wire low down and under the oil and water pump assembly at the front of the bike. Chances are, if you try to pull the rubber cover off then everything will split. Trace it back up to the front right of the frame: IIRC it's the only 'single' connector in the wiring loom. Earth the end that disappears into the main wiring loom.
There's a list of 'points' for certain types of modification. Once you exceed a certain number of points, it becomes a completely new vehicle and has to be tested as such. Some mods are instant 'new machine'. If it requires an MSVA, when you have passed the MSVA test, only then can you get it MOT'd. These links should help:-
https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/194159/MSVA_Guide.pdf
https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/366046/msva-manual.pdf
I think you maybe in MSVA territory because you've modified the frame (seat loop). Best talk to a local MOT inspector or ring VOSA and have a chat with them. You really don't want to get into trouble with the law.
15 Re: Neutral Light Thu May 10, 2018 9:09 am
Stumpy
Not one hundred percent sure but, what if you connected both indicators each to the repeater and then the repeater to Earth. The relevant side should power the repeater.
16 Re: Neutral Light Thu May 10, 2018 9:25 am
Then you you also must add a diode between each circuit and the repeater,
or you gonna end up with a hazards flasher.
17 Re: Neutral Light Fri May 11, 2018 6:45 pm
DBRMN
If I have bar end indicators do you think an indicator repeater is necessary as you can literally see when your indicating?Dai wrote:The indicator repeater is the amber (sometimes green as on the K) light in the instrument panel that flashes in time with the indicators. Some bikes have two (one for each side, like the K) and some have only one. If you fit one for each side then you run the same coloured wire for that side to the repeater bulb and earth the other side of the repeater. On a K that's a blue/black wire for the right side and a blue/red wire for the left side. For a single repeater bulb, you would connect the K blue/black wire to one side of the bulb and the blue/red wire to the other side of the bulb. On the face of it that should not work because you appear to be feeding two positives to the indicator repeater. In operation, only one side gets 12 volts (the side that is flashing) and the other side earths through the non-flashing bulb filaments. If you're doing any form of physics, your tutor can give you the lowdown on the whys and wherefores of it working.
Okay I think I'm going to try this after I've finished the cowl because I'm rushing to get that to the paint shop. I had a quick look and I think I know which wire it is, I'll attach a picture later.
In terms of structural the hoop is the only thing I've changed and that's now welded on. All the other changes have been tiny little things like different headlight, custom seat, speedometer stuff like that. Thanks for that document I've been looking for that for ages I just didn't know what to search. See picture.
18 Re: Neutral Light Sat May 12, 2018 11:52 am
In theory, no, but as I said, I'm not sure how many MOT testers would be aware of that particular quirk in the C&U regs.DBRMN wrote:If I have bar end indicators do you think an indicator repeater is necessary as you can literally see when your indicating?
I think it does come under the MSVA because moving the seat hoop is a structural change (unlike just cutting off or welding on new brackets). That's why I advised talking to VOSA.
19 Re: Neutral Light Sat May 12, 2018 4:26 pm
DBRMN
Ye I get you I might install a light then we'll see.Dai wrote:In theory, no, but as I said, I'm not sure how many MOT testers would be aware of that particular quirk in the C&U regs.DBRMN wrote:If I have bar end indicators do you think an indicator repeater is necessary as you can literally see when your indicating?
Oh god, don't a lot of people have this trouble cause most cafe racer's modify their rear hoop? Would you advise I call them or email them?
20 Re: Neutral Light Sat May 12, 2018 7:19 pm
Call them and get any confirmation by email. You may get told straight away not to worry. The real problem will come when you try to insure it. One of the questions you will be asked is 'have you made any mods to the bike?'; under that situation you will be in a position to quote chapter and verse:
Yes - it's been MSVA'd
Yes - VOSA said there is no need to MSVA and here's the proof.
If you don't comply with the absolute last letter of the insurance, the underwriters will wriggle out in the event of an accident. Remember: their loyalty is to their shareholders, not to you.
21 Re: Neutral Light Sun May 13, 2018 2:31 pm
DBRMN
Yeah very important to think about thanks for your help. Do you know if tracks will let you ride a modified bike without it being insured if your underage? And if it does or doesn't have a MSVA or VOSA?Dai wrote:Call them and get any confirmation by email. You may get told straight away not to worry. The real problem will come when you try to insure it. One of the questions you will be asked is 'have you made any mods to the bike?'; under that situation you will be in a position to quote chapter and verse:
Because I want to be able to ride it before I'm 21.
22 Re: Neutral Light Sun May 13, 2018 3:59 pm
Terms and conditions might vary from track to track. Riding in a track day event without insurance doesn't seem like a good idea unless you have access to plenty of money to recover your bike and body from damage.DBRMN wrote: Do you know if tracks will let you ride a modified bike without it being insured if your underage? And if it does or doesn't have a MSVA or VOSA?
Anyway, here's one outfit's requirements. http://www.silverstone.co.uk/terms-and-conditions/bike-track-days-terms-conditions/
23 Re: Neutral Light Sun May 13, 2018 10:22 pm
Point 17 is the relevant one. It's not just you - it's the other rider that you hit/hits you.Laitch wrote:Anyway, here's one outfit's requirements. http://www.silverstone.co.uk/terms-and-conditions/bike-track-days-terms-conditions/
24 Re: Neutral Light Mon May 14, 2018 5:38 pm
DBRMN
Think I need to try and get myself an ACU license. Yeah true.Laitch wrote:Terms and conditions might vary from track to track. Riding in a track day event without insurance doesn't seem like a good idea unless you have access to plenty of money to recover your bike and body from damage.DBRMN wrote: Do you know if tracks will let you ride a modified bike without it being insured if your underage? And if it does or doesn't have a MSVA or VOSA?
25 Re: Neutral Light Mon May 14, 2018 5:39 pm
DBRMN
Can you get track specific insurance even if your underage?Dai wrote:Point 17 is the relevant one. It's not just you - it's the other rider that you hit/hits you.Laitch wrote:Anyway, here's one outfit's requirements. http://www.silverstone.co.uk/terms-and-conditions/bike-track-days-terms-conditions/
26 Re: Neutral Light Mon May 14, 2018 7:59 pm
Items #6, #7, and #8 at Silverstone's site make it clear what ages and under which qualifications riders can use the track. Insurance is the rider's responsibility but it is not in the best interest of insurance companies to write policies for underage riders. Their risk of having to pay out is too high.DBRMN wrote:Can you get track specific insurance even if your underage?Dai wrote:Point 17 is the relevant one. It's not just you - it's the other rider that you hit/hits you.Laitch wrote:Anyway, here's one outfit's requirements. http://www.silverstone.co.uk/terms-and-conditions/bike-track-days-terms-conditions/
Be patient so you can at least reach the qualifying age.
27 Re: Neutral Light Tue May 15, 2018 11:42 am
I lament the dearth of old airfields where we learned to ride. I had the luxury of a mile of dead-straight runway with huge sweeping taxiways back to the start... they used to launch B-17s from there. Most old airfields are now nothing but housing estates.
An ACU licence is a good idea but as ever, read the small print very carefully. I'm completely out of touch with the current ACU requirements.
28 Re: Neutral Light Tue May 15, 2018 11:59 am
Mutually-assured destruction had its up-side back then. Those were the days.Dai wrote:I lament the dearth of old airfields where we learned to ride. I had the luxury of a mile of dead-straight runway with huge sweeping taxiways back to the start... they used to launch B-17s from there.
29 Re: Neutral Light Tue May 15, 2018 5:55 pm
Here's the one I learned on:
https://www.google.co.uk/maps/@53.0065381,-1.7055839,1218m/data=!3m1!1e3?hl=en
Definately not much left of it. Back then (1970s) it was still a Class 3 airfield i.e. open for use at your own risk, but no control tower etc.. The north side of the airfield is Bradley Woods where I fell out of more trees than enough. North of Bradley Woods on the A517 is where I got a Garelli Rekord moped up to an indicated 68mph down Shepherd's Hill... bollox, I'm getting old.
30 Re: Neutral Light Sun May 20, 2018 9:36 pm
DBRMN
Yeah fair enough trouble is I'm too excited lolLaitch wrote:Items #6, #7, and #8 at Silverstone's site make it clear what ages and under which qualifications riders can use the track. Insurance is the rider's responsibility but it is not in the best interest of insurance companies to write policies for underage riders. Their risk of having to pay out is too high.DBRMN wrote:Can you get track specific insurance even if your underage?Dai wrote:
31 Re: Neutral Light Sun May 20, 2018 9:36 pm
DBRMN
Ye I've heard of strips of tarmac near me I need to explore that idea!Dai wrote:I lament the dearth of old airfields where we learned to ride. I had the luxury of a mile of dead-straight runway with huge sweeping taxiways back to the start... they used to launch B-17s from there. Most old airfields are now nothing but housing estates.
32 Re: Neutral Light Sun May 20, 2018 9:37 pm
DBRMN
Exactly what I've want to do ahahaDai wrote:Here's the one I learned on:
Similar topics
