1 Exhaust Nuts and Washers Sun May 22, 2016 5:40 am
Rickmeister
Finally bit the bullet and fitted an Aussie made "Staintune" muffler today. When I removed the original muffler and header pipes (in one piece) I didn't see any copper washers/gaskets fall out of the exhaust port. When I fitted the new muffler and header pipes (about 10Kg lighter!!), I used the original copper(?) nuts and the original copper washers/gaskets (which I couldn't see)
Should these be replaced? Took the Yellow Beast for a 20Km jolly, up to 7½ - 8 thousand RPM at times, and the new system didn't miss a beat (ie, it didn't blow up!!) and it sounds GREAT!!
There didn't appear to be any gas/noise leakage at the exhaust ports.
Checked the LHS pannier and it still fits, with about 2" of clearance between the muffler and the bottom of the pannier.
