1Back to top Go down   1992 k75 32 amp alternator ability Empty 1992 k75 32 amp alternator ability Mon Jan 21, 2019 10:10 pm
lefthander
lefthander
I have a 1992 k75 with from what I've read here it has a 32 amp alternator. I am going to add the Symtec heated grips per Ducks instructions using an OEM grip switch. My question is if I am wearing an electric jacket liner plugged into the BMW outlet with a GPS plugged into the cigarette lighter plug would I be over stressing my system? Electrical is a big weakness of mine and I don't want to fry anything. Thanks in advance for any insite. ;BMW; ;BMW;
2Back to top Go down   1992 k75 32 amp alternator ability Empty Re: 1992 k75 32 amp alternator ability Mon Jan 21, 2019 10:17 pm
You should be OK I think.  (Don't worry about the GPS - very small electrical load.)
Try it out with both the heated grips and jacket on full.  The alternator light in the cluster may glow a little but if it starts getting brighter then turn the jacket off.  If you "overtax" the system it won't hurt anything it just doesn't charge the battery. Turning the jacket off will get the battery charging again.
Do you have a manual for the jacket?  How many watts does it use on full?
3Back to top Go down   1992 k75 32 amp alternator ability Empty alternator capacity Mon Jan 21, 2019 10:39 pm
lefthander
lefthander
Hey Duck, It's from Aerostich. I'll look it up tomorrow and post it. Thanks for the quick reply.
4Back to top Go down   1992 k75 32 amp alternator ability Empty Re: 1992 k75 32 amp alternator ability Mon Jan 21, 2019 10:47 pm
I looked it up - 75 Watts. I think that might be just a tad too much but trying it out won't hurt.
Note that if you have a heated jacket liner and insulated gloves that heated grips aren't as necessary because the heated jacket liner keeps your body core and arms warmed up so you're pumping warmer blood to your hands.
5Back to top Go down   1992 k75 32 amp alternator ability Empty Re: 1992 k75 32 amp alternator ability Mon Jan 21, 2019 11:23 pm
I would estimate your approximate current draw as follows:
6-9 amps- Jacket and grips
7-10 amps- Headlight, tail light, brake light and turn signals
5-8 amps- engine operation(fuel pump, injectors, ECU)
3-4 amps- instrument cluster, GPS
If you add halogen running lights, you will probably be overloading the alternator.  If you have running lights, it would be better if they were LED.  Don't worry about your GPS, they typically draw less than 1/4 amp.
6Back to top Go down   1992 k75 32 amp alternator ability Empty Re: 1992 k75 32 amp alternator ability Mon Jan 21, 2019 11:28 pm
ETK say they're 33Amps which x 12Volts equals about 400Watts (396W to be exact). My '87 RS has the same alternator and I can roll down the motorway at legal speeds or less powering two heated jacket liners (a Gerbing @ 77Watts & a Powerlet Atomic Skin a bit less) at full blast on a frigid day. I don't have heated grips on that OZ-based bike. My AGM battery has never even hinted that it struggles to start during a trip like that, and the alternator light isn't glowing.
Same deal on my '77 Airhead with a Motorad Elektrik 400 Watt upgraded alternator. Heated grips switched to high and a Gerbings full heated liner and we're off. It does have a 28Ah battery so perhaps a bit on reserve over the 19Ah K100RS, but never a problem. Caveat: the bike isn't fuel injected with its bigger draw than a set of carbies (zero draw) and basic wiring loom stuff, H4 headlamp, taillight, indicators, etc., but does now have electronic ignition...
Back in "the day" the original dodgy 280Watt alternator on my Airhead still managed to power my ancient (forget the brand name, now defunct) heated vest with nary a drama. I just couldn't idle it round town too long, but out on the road above 3,000RPM it was all warm and fuzzy.
I reckon you're good to go.
7Back to top Go down   1992 k75 32 amp alternator ability Empty Re: 1992 k75 32 amp alternator ability Tue Jan 22, 2019 12:02 am
My power guess is based on a 93 K1100LT when it had the old alternator.  Before I upgraded it to a 50A alternator the battery would drain if I ran the OEM heated grips and a pair of 35W aux lights.  So my rough math tells me 100W+ was too much.
It may be that the 4V bikes suck more power for the basic power stuff though so a 2V may have more "spare" watts from the smaller alternator.
8Back to top Go down   1992 k75 32 amp alternator ability Empty Re: 1992 k75 32 amp alternator ability Tue Jan 22, 2019 12:06 am
At the end of the day it's no harm to run heated grips and a jacket liner or vest, just watch the charge rate by keeping an eye on the alternator light, and know that at night when home you just whack the battery tender on before you go night night.
For yucks, attach your multimetre to the battery, run the engine through a rev range typical of where you'll ride while switching your accessories on maximum. 12.6 to 14+Volts  or so and as we say Down Undah, 'you'll be laughing.' Another option: attach a slim LED voltmetre directly to the battery. They make 'em tiny and stick on nowadays. Keep an eye on it while riding. For sure, nothing's gunna blow up.
9Back to top Go down   1992 k75 32 amp alternator ability Empty Re: 1992 k75 32 amp alternator ability Tue Jan 22, 2019 12:15 am
Good point. My battery ran down when running errands in the city so the alternator wasn't putting out 14V the whole time.
10Back to top Go down   1992 k75 32 amp alternator ability Empty Re: 1992 k75 32 amp alternator ability Tue Jan 22, 2019 5:16 am
nino
I had similar problem with 32 amp alternator on K 100, but since I changed voltage regulator problem dissapeared. As I understood old voltage regulator was 14,4 volts, but new one 14,5 volts. It charging a battery in city traffic very well even with two fog lights. You can try maybe.
Regards.
11Back to top Go down   1992 k75 32 amp alternator ability Empty Re: 1992 k75 32 amp alternator ability Tue Jan 22, 2019 7:55 am
Just a general FYI: when calculating electrical loads, the indicators, horn, brake lights and any warning lights are classified as 'intermittant supported by the battery' and are ignored for the purposes of figuring out the total steady load supported by the alternator.
12Back to top Go down   1992 k75 32 amp alternator ability Empty Re: 92 k75 alternator amps Tue Jan 22, 2019 7:03 pm
lefthander
lefthander
Thank you to all for the info. I'm very much getting attached to the bike. And to all the help here when trying to sort things out, it's much appreciated. The bike just turned over to 40,000 miles as I pulled into my garage last night. I feel confident I can keep it going a long time as it seems to run really well. For a bike that's aprx. 27 years old I'm impressed by how good it runs. Even after sitting for about 5-6 years in my sons garage.
  Peace
13Back to top Go down   1992 k75 32 amp alternator ability Empty Re: 1992 k75 32 amp alternator ability Tue Jan 22, 2019 7:23 pm
40K?  Just getting broken in.
