Number of posts : 4467
The only difference is that the 96 cluster has a Pin 12 to illuminate the second ABS indicator. (Where the choke indicator used to be.) Your 91 has no wire to Pin 12.
Aside from that all should be the same so the 96 cluster should work just fine on a 91 4V.
