FreyZI
FreyZI
I'll post gaps in a bit, but is there anything to explain mostly tight clearances in '85 K100 2V?
Wear.
How many miles on the bike? Do you know if the clearances have ever been checked previously?
FreyZI
FreyZI
Alda has ~104K mi.  I have no idea when it was last serviced.
Clearances:
I1 .152
I2 .127 (tight)
I3 .127 (tight)
I4 .152
E1 .229 (tight)
E2 .178 (tight)
E3 .279
E4 .229 (tight)
Incidentally, I took the muffler/silencer off to look at header pipes for oil.  Headers from cylinders 2 and 4 appeared oily; 1 and 3 were dry).
What that means is that most of your valve clearances are tight. Not by much and that they have been neglected and need to be rectified. Check them each major service and adjust as necessary.
Inlets 1 & 4 @ 0.152 I would call tight also. While still in spec (just), I doubt it would be long before they were out as well. Best to re-shim them all to the loose end of the spec.
 What does it mean that most of my valve clearances are tight Austra12    Fuel:  95 Octane
its probably an early series motor
there was some speculation about unleaded fuels requiring better metallurgy of the valve train . engineering changes occurred back in the late 85 -86 models that changed the valves and seats for the better
long story short the early models may have softer seats ...allowing for what we call valve regression to happen more quickly when using unleaded fuels (LEADED FUELS PROTECT valve seats and exhaust valves better ) .. ie valve clearances gets tight
regression happens normally as seats and valves wear but in the earlier models this may happen quicker that later models
just get the shims required to make the clearances correct
your Kawasaki dealer usually carries shims for klr 650 bikes , which are a match for our valve shims  so possible readily available  for swapping .
my local Kawasaki service shop does them exchange for $5.00 each ...so could be better cost effective than buying new ?
good luck
You will need special tools to change the shims, you can get them from mailto:polepenhollow@yahoo.com.
It is also possible to make them, the drawing for the tool specs used to be online but I can't find it, somebody may post it. Basic hand tools needed files, hacksaw can be used although an angle grinder makes it easier. You will also need a welder to attach the handle.
Chocolate
Chocolate
Even though I have the special tools I find it easier just to use a screwdriver.  I put the blade tip parallel to the circumference though.
FreyZI
FreyZI
Thanks, all.  More fish to fry, as I've just removed head and this looks to be a more significant project.  I'll start a new thread.
FreyZI
FreyZI
Uff da.  So, I've just gotten the head back from the shop where they did a valve and seat job.  I also had them replace the valve seals while they were in there.  Nothing untoward noted.  Put cylinder head on cylinder block and reassembled the buckets, shims, cams, and caps on the head.  Now instead of the slightly tight gaps I had before, I have essentially zero gap at any shim.  Doesn't seem like anybody who knew what they were doing could put the valve assembly back together wrong (other than maybe lower spring plates upside down?).  Is this normal after disassembly of the valves?  Any suggestions?
Just to allay any potential concerns: copiously oiled parts during assembly, all the buckets and shims are on the valves they were on before, all the caps are in the same, correct places, slow and careful rotation of each camshaft is possible without particular difficulty or noises.
A service to the head and valves will usually mean that the valve faces and valve seats will be ground or machined, so the valve will sit slightly higher in the head. This will mean that they will be closer to the cam and so smaller clearances will be expected, with the amount of difference related to how much had to be removed to get a good seal.
If the clearances were unchanged, I'd be suspicious whether they'd done any work at all.  Smile
You will probably need to obtain some new shims, but you may be able to re-use some on different valves to get the right clearances.
FreyZI
FreyZI
Thanks, Bill.  Perfect explanation.
FreyZI wrote:Uff da.  So, I've just gotten the head back from the shop where they did a valve and seat job.  I also had them replace the valve seals while they were in there.  Nothing untoward noted.  Put cylinder head on cylinder block and reassembled the buckets, shims, cams, and caps on the head.  Now instead of the slightly tight gaps I had before, I have essentially zero gap at any shim.  Doesn't seem like anybody who knew what they were doing could put the valve assembly back together wrong (other than maybe lower spring plates upside down?).  Is this normal after disassembly of the valves?  Any suggestions?
pretty common issue
when I did my head porting project , I asked them how much total they had removed from the valve faces and valve seats ...was about 10 thou in total ...
so I got them to trim the valve stems (length of valves ) by about the same amount ...so result was 7 of the 8 valves were extremely close to spec ...but 1 valve was another 6 thou loose ...I guess they hit that one twice ....lol
but still in range for a standard shim ..so most were around 2.4 - 2.6 thickness but the rancid one 2.85 ...bugga ...the local kawaski dealer does an exchange service with klr 650 shims for $5.00 each ...so all sorted
good luck
I've heard many scary stories about valve recession on BMW engines.
I've also opened and overhauled many BMW engines. Hundreds. From 1970 to 1995.
I've seen ONE recessed (?) seat, measured out of the limits. Only one - exhaust- on only one cylinder.
If unleaded fuel was to blame for this, it would have caused recession on all the cylinders, don't you think?
I would blame the valve guide for destroying the seat instead. The valve has not only a movement in translation but is also turning (it's normal, to spread the wear all around the seat). But when the guide is worn, this rotation is not coaxial anymore, and the valve is grinding and digging in the seat.
Valve guides are wearing much quicker than seats. When they are replaced, valve seats need to be machined to maintain the valve, the seat and the new guide coaxial. So according to me, we should pay attention to the guides much more than to the seats.
well interesting you should say that jbt
that is why I reconditioned the head
pitting of the valves was consistent across all valves but much more evident on the exhaust valves
heres an example
What does it mean that most of my valve clearances are tight 2013-010
cleaned up a little
What does it mean that most of my valve clearances are tight 2013-011
and an inlet
What does it mean that most of my valve clearances are tight 2013-012
What does it mean that most of my valve clearances are tight 2013-110
after service  what I put back in
What does it mean that most of my valve clearances are tight 20141210
seats
 What does it mean that most of my valve clearances are tight 2013-013
and after
What does it mean that most of my valve clearances are tight 20141212
Good idea on shaving the Valve stems/shafts. I'll do that with K1100rs head.
@ Charlie.....did you see how they did the job? Just wondering how they would chuck the flared end of a valve!
What does it mean that most of my valve clearances are tight Ir-log1188....May contain nuts!What does it mean that most of my valve clearances are tight Ir-log11
K75RTP - 1994
Will - you clamp it on the parallel part of the stem and give it a virgin's kiss with the tool.
(Damn - somone's gonna get me with that one).
most of the engine re-conditioners have special grinding wheels set at appropriate angles will
for the special performance types they can do a 3 angle cut of the valves ,but many performance mods have geared up for 5 cut angles at exorbitant prices
the refurb of my valves was only a 1 cut angle ...and still within spec for the distance from the valve face (by a certain amount )  I was happy with the angles of the grind to allow the angles of the natural valve profile to flow a 3 angle process , you may have noticed that the exhaust valve had a protruding edge above the valve face , after which was cut back to nearly no protrusion in the edge  and more a straight cut - edge
the tool doing this was like a fine stone on a bench grinder with preset angles on the valve stem guides to the grinder '' there was a heavy reliance of estimation to how much was ground off , by the operator of the equipment
in truth I hadn't done my homework properly and should have measured the lengths from top of seat  to valve stem top  to estimate how much they had either removed  or what ever , I would imagine to do this might have been out of my skillset , with the tools I had to hand .
but may have been replaced into to the cylinder head and reassembled before estimating the top cut required  to fall close to the original shim thickness ..then work with the calculator
hope that answers some questions ?
https://www.youtube.com/watch?v=y5nTXDIgWaM
Serco cutters are more common in the UK.
nobbylon
nobbylon
I just did my clearances yesterday. Bike has 84k kms and is a very early model so was built to run on leaded. Only 2 inlets were tight. Previous owner didn’t but I will be using shell millenium fuel additive. I think these K engines are fine valve wise on any fuel.
There have been many here who have found the early heads to be quite tolerant to the unleaded fuel but a few have cropped up that have been failing and needed fixing.  Thing is that after 30 years and more the heads probably have been swapped or fixed so fewer and fewer are surfacing and more than likely on engines that have been found in the back of a barn or cave after being there for many years.
The other thing that helps is the material that the valve seat is made of. I have no idea what BMW used but there was a huge panic in the Guzzi world when leaded fuel went out. Turned out that the valve seats were old enough to have work-hardened and be immune to unleaded fuel. Mind you, I have two burnt-out exhaust valves on the shelf...
