1 86 K100 RS Cracked Ignition Coil Wed Dec 19, 2018 4:28 pm
highflyer
Hi all, on removing the ignition coils on my 86 K100 RS project build, I noticed that one is cracked - presumably this coil will need replacing? They seem to be quite expensive, so was wondering if they can be repaired? The affected coil is the forward coil for cylinders 1 & 4. The other coil seems to be fine. Thanks in advance for your feedback
