1 Ignition Switch Removal and Replace with Maintained Switch Tue Apr 03, 2018 10:36 pm
jmccrary
I did some searching and did not see anywhere. I want to remove the ignition switch and replace with a maintained single-pole, single-throw switch. I was reading the wiring diagram and just wanted to double check something. I have never hot-wired a vehicle, but it appears that the I will need two switches.
Switch One - Red/Green wire
Switch Two - Green-Blue/Grey
Then to start the bike, both of those switches will need to be flipped "on".
Can someone please confirm my theory? I did some searching, but could not find anything in this area. TIA!
