1 1986 Rear Shock oil change - possible ? Wed Mar 07, 2018 7:43 pm
johny brando
Hi all , with respect ...I'm not after any general or obvious health & safety advice here thank you ! I'm specifically asking....If any one has attempted to change out their Std K100 rear shock damping oil ( this is on the STANDARD ---- "NONE Nivomat shock absorber" )as it reads & appears that to all intense & purpose's this unit is none- serviceable !
I am very aware of the doe's & don't of working with sealed pressure vessels . I'm asking if any one has prior actually successfully done this , or am I gunna be the first to attempt it on an otherwise good condition 32 year old shock absorber . I expect to have to drill 2 small holes in the damper housing body .....1 at the @ highest practical damper point & the other @ the lowest practical damper body point, this to be able to both vent & drain then refill the damping oil .........then perhaps tap & thread these holes so as to seal / plug them ......... or maybe even if required very carefully Tig Up the holes... if taping the threads are not possible . I'm asking for input here from any one thats actually done this ! & I'm asking to please maybe draw on your experiences & any issues that you may have had to overcome on this particular exercise & ask what grade / weight of oil you found best suited . PLEASE REPLY WITH A PM TO ME....... THANK YOU for your help here !
