1 Not funny at the time Wed Apr 11 2018, 15:28
audibob
I have put this sorry tale in the Humour section instead of Engine and Transmission.
I decided to replace my rear Main seal and clutch O ring as I intend to keep my K for many years.
First hint of humour came when I had to remove the exhaust.
The little guy in the back of my mind said " I wish my exhaust was as shiny as the example set by one of the guys here "
Okay, exhaust seperation came and abruptly stopped when pipe number 4 refused to budge.
At this point I should have refitted the other pipes back to the muffler and carried on.
but I didnt listen.......
I decided it needed more heat and that meant some serious heat, so I contacted a guy at the local car garage I knew and left it with him.
Big mistake. his guy got it off alright, but left gauge marks on the pipe where his 36 inch stillson had been
and he charged me 40 quid for his time ...and thought he was doing me a favour
The job itself was fine, allowing the new seal to be preshaped via a pill bottle overnight, prior to refitting .
A new friction plate for the clutch went in .
Only one exhaust stub sheared off, which was drilled out to 6.5mm and then 8mm starter and final taps to remove last remnants of the broken stud.
I then found that replacements exhaust studs are too short by about 10mm which meant holding the new stud via its allen key slot in the end and turning the nut at the same time to secure the flanges
All exhaust pipes were cleaned via a brass brush wheel on grinder, not like new, but shiny enough to double the value of the bike from at least ten yards...
and then.....number four exhaust pipe would not line up . miles out ......
Had to reduce the pipe by a couple of inches to allow the pipe to line up with its flange.
I was trying to imagine how the guy at the garage got the pipe out of the muffler,,
He was a big guy, very amiable , but perhaps not on my list of people who I trust to do jobs for me anymore
and definitely off the Christmas card list.
Took me ages to refit the exhaust, fully expecting a leak somewhere, but none , so that was a my live and learn moment.
Bike started perfectly, clutch seems good, time to clean tools and the garage, and finally go over torque setting on everything . Then time for my first ride in a month .
God I miss riding my K..
Bob
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
