1 Another 90 K100RS no start Fri Jan 05, 2018 1:38 am
MikeGandy
Hi, so theres a bit of a story and i will do my best to explain it.
A pulled a 90 K100 16V out of a barn after it had been sitting for about 10 years, it only had 20kms on it.
I got it going and rode it for a short time, during that time i removed the faulty ABS.
It became apparent that during storage everything had perished and i pulled it apart to complete a rebuild.
I put it back together as a Cafe Racer, put a BEP 3.0 in to replace the dash (tried before i pulled it apart and worked fine).
After putting it back together i couldn't get it to spark, initially i went over all my earths and connections, they've ll been clean and lubricated, twice .....
I replace the hall sensor with a new out of the box replacement, still nothing.
I checked my coils and i have a green constant when you turn the key and a black and red to one coil and a black and blue to the other, i checked both earths on the coils as well.
I replaced the HALL sensor thinking that it was the most likely cause, the Fuel injection and fuel pump are working(and was before this) but thought it may be effecting the spark.
After this i replaced the computer and also the Bosch ignition module.None of these things have made any difference.
What i have is a black and white wire coming into the Bosch ignition module.When you turn the key its earth, when you crank it over it turns to a power going into the ignition module.
Then at the coils both the black/red and black/blue have power to them as well as the green, but no spark, funnily enough the tester made the black/blue wire earth and the spark plug sparked briefly so the coils and the leads are fine.
So, what i'm wondering is should the black/white wire pulse and if so is this from the HALL sensor ?
Any help would be appreciated although i understand that
Any help would be appreciated as i'm stumped, i got a mechanic to come and have a look and after about an hour or two he was stumped as well. The only wiring altered was adding the BEP, i have tried it with the factory dash and its made no difference.
I've replaced the Hall Sensor, Computer, Bosch ignition module, all new apart from the computer.
I hope this makes sense,
Mike
Mike
